Brake Master Cylinder Refurb
Elmo
Would it be OK to remove the guts from a new LHD master cylinder to refurb my RHD, I'm assuming the innards are the same, it's just the housing that is different, am I right?
Cheers.
Someone more knowledgeable on the subject will be able to let you know exactly but I would like to say, I would be more concerned if it was ABS or not. I don't think they are interchangeable.
Thanks for your reply.
I have ABS, but you think as long as the LHD master cylinder is ABS the internal parts should be compatible?
