Murf2j Posted June 3, 2014 Share Posted June 3, 2014 (edited) Could someone help me pinpoint a problem before I start buying parts or pulling the car apart, all lights are working fine apart from normal front driving lights, so thats fogs, high beam and side lights that are working but no low beam . I have checked fuses,bulbs and relay but no luck, I have a spare indicator stalk as a mechanic said it could be the switch on there? If someone could give me any more ideas on an insight that would be great?? Edited June 3, 2014 by Murf2j Put dogs instead of fogs (see edit history) Quote Link to comment Share on other sites More sharing options...
listy Posted June 3, 2014 Share Posted June 3, 2014 Do you have HID ballasts fitted? If so, try swapping the wires around, as sometimes they need to be reversed to work. If not, and it may sound silly, but have you checked the bulbs are fitted correctly/not blown? Quote Link to comment Share on other sites More sharing options...
Murf2j Posted June 3, 2014 Author Share Posted June 3, 2014 Problem sorted cheers for the quick reply, was standard bulbs with a bad earth, just fitted my HID's to and your right about them, they need to be reversed, thanks again Quote Link to comment Share on other sites More sharing options...
