rdwg Posted June 1, 2014 Share Posted June 1, 2014 Has anyone had any experience with the "O/D off" warning light flashing on and off The O/D works fine and can be turned off as normal but when it is switched on - it flashes on and off I suspect an electrical fault but just wondered if anyone else had experienced it Link to comment Share on other sites More sharing options...
LOGIE Posted June 1, 2014 Share Posted June 1, 2014 Usually indicates an autobox fault. Have you changed the oil and strainer lately? Check all electrical connectors on the box also. Check ATF level also. Link to comment Share on other sites More sharing options...
Tommyd16 Posted June 1, 2014 Share Posted June 1, 2014 Does mean you have fault codes Link to comment Share on other sites More sharing options...
mr two Posted June 1, 2014 Share Posted June 1, 2014 Has anyone had any experience with the "O/D off" warning light flashing on and off The O/D works fine and can be turned off as normal but when it is switched on - it flashes on and off I suspect an electrical fault but just wondered if anyone else had experienced it I had this problem with the 1st Supe i owned a few years ago ..happened when my speedo stopped working...got the speedo fault fixed and o/d light stopped flashing.. Link to comment Share on other sites More sharing options...
peter richards Posted June 1, 2014 Share Posted June 1, 2014 speed sensor is the most likely fault , mine starts flashing over say 60 ,red triangle then comes on , car drives ok , bit annoying but ive got used to it Link to comment Share on other sites More sharing options...
scott.wild Posted June 1, 2014 Share Posted June 1, 2014 Try getting the error codes, the usual culprit is a speed sensor or speed converter if you have one fitted. It could also be a lose cable/connector somewhere, i hopefully have resolved mine after changing the gearbox oil/filter and solenoids and the autobox ecu. Fingers crossed. Link to comment Share on other sites More sharing options...
scott.wild Posted June 9, 2014 Share Posted June 9, 2014 (edited) Did you manage to get the error codes, i think i have finally fixed mine, 2 blown capacitors in the ECU. Edited June 9, 2014 by scott.wild Wrong post (see edit history) Link to comment Share on other sites More sharing options...
