Auto O/D off warning light
rdwg
Has anyone had any experience with the "O/D off" warning light flashing on and off
The O/D works fine and can be turned off as normal but when it is switched on - it flashes on and off
I suspect an electrical fault but just wondered if anyone else had experienced it
I had this problem with the 1st Supe i owned a few years ago ..happened when my speedo stopped working...got the speedo fault fixed and o/d light stopped flashing..
Try getting the error codes, the usual culprit is a speed sensor or speed converter if you have one fitted. It could also be a lose cable/connector somewhere, i hopefully have resolved mine after changing the gearbox oil/filter and solenoids and the autobox ecu. Fingers crossed.
