Tommyd16 Posted May 29, 2014 Share Posted May 29, 2014 Been reading up on this. Seen some different views do just want to clear it up. -Drain a litre or so off and top up That correct. Not drain the whole box? Also is there a drain plug or is it easier just to disconnect one of the cooler hoses and drain it off a little from there? Link to comment Share on other sites More sharing options...
Lee P Posted May 29, 2014 Share Posted May 29, 2014 Drain the sump via the drain plug, it should have just under 2 litres in it. Refill through the dipstick If you want to change all the fluid and flush it it gets a bit more complicated Link to comment Share on other sites More sharing options...
