Kendo11 Posted May 26, 2014 Share Posted May 26, 2014 Afternoon. Currently have my car on axle stands so as to sort what I think is air in the power steering system. It's also been leaking bad. I'm doing the engine off lock to lock thing and if I've read previous threads right, the fluid should overflow? Mine is just staying at the cold level and not overflowing at all, and I'm not seeing a great deal of air bubbles either. Main question is - if it's not overflowing, what's wrong with it? As for the leak, can I use a power steering leak sealer? Thanks Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted May 26, 2014 Author Share Posted May 26, 2014 Starting to see a few small air bubbles when I dip the cap in and out but still no bubbling up Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 26, 2014 Share Posted May 26, 2014 Can you see where its leaking from mate? I cleaned the area thoroughly when I fitted that pump, it should be fairly obvious. Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted May 26, 2014 Author Share Posted May 26, 2014 Bloody everywhere haha. I've topped it up with leak sealer, and will be ordering a new unit tonight. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 26, 2014 Share Posted May 26, 2014 Haha, there must be one spot, theres only 1 high pressure connection, maybe its the crush washer? I'm home until wednesday night if you want me to have a look? Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted May 26, 2014 Author Share Posted May 26, 2014 It might be the washer mate. To be honest with the wheel wobbly too I'm just going to order a replacement one and hope it's better than the last one. Plus I'm away tomorrow. Taking it on a 4 hour drive. ...risky Quote Link to comment Share on other sites More sharing options...
