Si_s Supe Posted May 25, 2014 Share Posted May 25, 2014 I seem to have sprung a leak! But, it only seems to come on when I park up after a spirited drive. Normal driving it's ok. I'm struggling to see where it's leaking from so I thought I'd post to see if there's any usual suspects? My guess is the rad, but visually in situ it looks mint! The coolant is dripping from the cross member which runs underneath the rad. Here's a quick iPhone video taken just now after parking up at home. http://youtu.be/wE2zPpxkJog Any pointers gratefully received before I resort to pulling the rad out. Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 26, 2014 Share Posted May 26, 2014 As it looks dry high up I think it may be the lower part of the rad, there can be quite a build up of leaves and assorted crap between the rad and the aircon rad which retains moisture and can rot the radiator over time. It might pay to remove the plastic shroud or even the lower 2 bolts if you want to try and locate the precise source of the leak. Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 26, 2014 Share Posted May 26, 2014 If the top & bottom hoses aren't leaking where they attach to the rad then it cant really be from anywhere else, wheres the expansion tank and its overflow pipe located ? Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted May 26, 2014 Author Share Posted May 26, 2014 Scott, you're quite right, there is quite a build up of debris between the two. Have also now noticed that that the piece of sponge along the bottom of the rad is saturated. Guess there could be a problem at the bottom somewhere. Dnk, the expansion tank is in it's stock location, in front of the slam panel. The overflow is just a short 90 degree pipe coming off the cap. All dry there. Point to note though, the expansion bottle does run very low. The rad level however stays up. Quote Link to comment Share on other sites More sharing options...
Pulley Posted May 26, 2014 Share Posted May 26, 2014 Can be the crimps have loosened and its pushing past the crimp seal rubber gasket The top and bottom plastic ends of the rad have lots of little fingers that are crimped over to hold the ends on If they pull apart slightly they can allow coolant to seep out under pressure That or the rad matrix has rotted Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 26, 2014 Share Posted May 26, 2014 Can be the crimps have loosened and its pushing past the crimp seal rubber gasket The top and bottom plastic ends of the rad have lots of little fingers that are crimped over to hold the ends on If they pull apart slightly they can allow coolant to seep out under pressure That or the rad matrix has rotted Time for a new rad i'd have thought if it's the original Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 26, 2014 Share Posted May 26, 2014 Pages co 18 and co 24 onwards in the PDF below might be of interest to you but if its an old rad i'd be biting the bullet and fitting a new oneCO.pdf Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted May 26, 2014 Share Posted May 26, 2014 I had this issue recently, it was the water pump Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 26, 2014 Share Posted May 26, 2014 I had this issue recently, it was the water pump How did the water pump cause coolant to drip from under the rad onto the cross member ? Quote Link to comment Share on other sites More sharing options...
quarryman Posted May 26, 2014 Share Posted May 26, 2014 this is just a thought but an xjs of mine was ok driving ok but leaked if i give it some,, i found if i revved it above 3000 rev's it leaked from a hose, get someone to watch as you rev it up Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted May 26, 2014 Author Share Posted May 26, 2014 How did the water pump cause coolant to drip from under the rad onto the cross member ? Christ, yeah...how did that happen? Hopefully mine isn't the water pump. With the typical Bank Holiday weather, I've not been able to investigate today. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted May 26, 2014 Share Posted May 26, 2014 Ignore me, I didn't read the the thread properly, mine started after being parked up 3 months and after some investigation it was the water pump..... Timing belt off job Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted May 27, 2014 Author Share Posted May 27, 2014 Ignore me, I didn't read the the thread properly, mine started after being parked up 3 months and after some investigation it was the water pump..... Timing belt off job Phew!! Haha. Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 27, 2014 Share Posted May 27, 2014 It's not that bad a job changing the water pump, a genuine pump from Toyota is around £100, CW i think does new OE spec rads for around £220 Quote Link to comment Share on other sites More sharing options...
