Engine mounts and block support brackets - how interchangeable?
Pete
I think the engine mounts need doing on my VVTi, I know they have different mounts (inferior weaker) than the original design.
To change them to the stronger original ones I'll need to also change the engine mounts.
Could anyone confirm if the block brackets are the same on the '93 NA and TT or if they were different?
Ta.
Edited by Pete (see edit history)
The toyodiy.com tool suggests they're the same:
http://www.toyodiy.com/parts/p_J_1993_TOYOTA_SUPRA_JZA80-AJPZZ_1107.html
('9305-   )
12311 BRACKET, ENGINE MOUNTING, FRONT NO.1 RH
12311-46090 1 $131.74
12315 BRACKET, ENGINE MOUNTING, FRONT NO.1 LH
12315-46090 1 $117.07
12360 INSULATOR ASSY, ENGINE MOUNTING, FRONT
12360-46070 2 $224.93
12371 INSULATOR, ENGINE MOUNTING, REAR NO.1
12371-46020 1 $92.16
90105-10117 *** STD. PART $1.62
90105-10245 *** STD. PART $2.06
90105-10417 *** STD. PART $1.27
90109-08210 *** STD. PART $4.03
90119-08770 *** STD. PART $1.27
90119-10524 *** STD. PART $1.27
90179-08159 *** STD. PART $1.27
90179-12153 *** STD. PART $1.54
90179-14055 *** STD. PART $1.94
91611-61030 *** STD. PART $2.21
Thanks David, that's interesting to see them side by side.
It's the block brackets I'm really trying to understand if there was a difference between NA and TT pre-facelift.
Not the difference between pre and post facelift mounts, I didn't make that clear sorry.
I attempted it precisely once in a single garage with bugger all room. Got as far as pulling the intake manifolds and related gubbins off, hit my head on the engine crane once too often, and called "FI". It doesn't knock and it's stopped leaking* so I consider it fixed ;)
-Ian
*yes, I'm fully aware of why
