Mr2 Screeching Sound
ccssupra
lol at tubbytwo.
seems a shame you can get a used one for around £30 or a recon for about £70.00 and its not hard to fit. Banger rally for a simple alternator swap seems a bit extreme
Tim
Its going on a banger rally anyway. Its a bit of a shed. The noise doesn't even come from the alternator, it comes from the throttle body
Already seen it thanks though
throttle body?
there isn't really anything there that can make that king of noise, you have the butter fly and the idle control valve thats about it. Although directly under the is the bellhousing and the gearbox. are you sure its coming from that area and does it make any difference in noise if you press the clutch?
Tim
Well it does seem to be the idle control valve. Only ever makes the sound at idle, and is more of an "instant" sound, it doesnt matter what revs the engine is at, the alternator would surley make a different sound depeding on speed.
The alternator seems to spin with the belt off smooth as silk, certianly doesnt indicate anything is wrong with it, and im not having any power issues.
