Jellybean Posted May 24, 2014 Share Posted May 24, 2014 Hey I Have an 93 car, she had the 12 bolt 220mm Diff from Factory (AKA UK Spec) , she has UK Brakes all round How do I know if she has UK rear brake rotors? They are different sizes to Jspec, does anybody know the diameter of UK and Jspec Rotors? On a side note , does anybody make a rear Brake rotor where the bellhousing doenst rust over time? Can you use any 2 piece rear rotor with OEM UK 2 pots, brembo, AP racing etc? Only rear brake Rotors I can see are OEM Rotora Stoptech Blueprint Black Diamond Does anybody have any experience of the Stoptech, cross drilled rotors look like a nice piece of kit http://www.mvpmotorsports.com/Merchant/catalog/jdm/t/supramkiv/p/stop/OED.jpg Quote Link to comment Share on other sites More sharing options...
Chris88 Posted May 24, 2014 Share Posted May 24, 2014 AFAIK J spec rear disc is 307mm diameter and UK spec rear disc is 324mm diameter. They're both 16mm thick. Quote Link to comment Share on other sites More sharing options...
David P Posted May 24, 2014 Share Posted May 24, 2014 (edited) http://mkiv.supras.org.nz/specs.htm http://www.clarkmotorsport.net/DBA-Brake-Discs/48.html Edited May 24, 2014 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted May 24, 2014 Share Posted May 24, 2014 (edited) Pics and specs here http://www.mkivsupra.net/vbb/showthread.php?249089-Supra-Brake-setups Endless, Project Mu and DBA all make 2 piece discs that fit the larger Supra brakes, I use to use Project Mu SCR Pro discs on mine, expensive but very good quality and very hard wearing. Edited May 24, 2014 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 26, 2014 Author Share Posted May 26, 2014 Nic said: Pics and specs here http://www.mkivsupra.net/vbb/showthread.php?249089-Supra-Brake-setups Endless, Project Mu and DBA all make 2 piece discs that fit the larger Supra brakes, I use to use Project Mu SCR Pro discs on mine, expensive but very good quality and very hard wearing. Thanks Nic, yeah I have the Project Mu SCR Pro discs on the front, just rears I am after - - - Updated - - - David P said: http://mkiv.supras.org.nz/specs.htm http://www.clarkmotorsport.net/DBA-Brake-Discs/48.html thanks David - - - Updated - - - Chris88 said: AFAIK J spec rear disc is 307mm diameter and UK spec rear disc is 324mm diameter. They're both 16mm thick. thanks Chris Quote Link to comment Share on other sites More sharing options...
