Chico Na-t Build
CHICO-SUPRA
hi guys thought id post a few pics of my Na-t build (pics below).Ive had the supra for 2 years and decided to go for a little more power by taking the Na-t route. I managed to remove the subrame completely with the guidance and advice from a fellow owner. cheers bud:thanks:.
from there it was easy to remove the lower and upper oil pan. Thanks josh and lee for the advice:thumbs:. I got the flange welded to the sump and thought id give it a clean. I sprayed the upper pan and powder coated the lower one. I then test fitted the turbo and manifold. I had to fabricate a new screamer pipe for the waste gate to get clearance.
Ive never played with an external wastgate but mine has 2 ports one on the bottom and one on the side. can some one tell me if I have to use both ports or just the one? I will be running a boost controller and gauges also, so what would be the best way to route the vac hoses? A diagram would be extremely helpful.
Cheers guys will post more pics when I get a chance,
Chico.
chico, welcome to the forum!
as for your question, I have no idea! but I am sure there are alot of folk on here that can answer your questions.
cheers bud, I thought it's about time I get on here and start learning sum info on my supra instead of messing things up and getting iky to sort them out.
