prosty Posted May 22, 2014 Share Posted May 22, 2014 Hello Have anyone fitted HEL brake lines to their car with the stock c-clips and pressure clip? Mine doesn't seem to fit that good. I can always tie it down with a zip tie or a hose clip but that seems a bit dumb , I thought the lines was supposed to fit just as good as the stock ones. The female connector that fits to the cars hardline doesn't look exactly like the stock ones, it fits fine and has the correct fitting (in the front) to fit the car, or is my c-clips just old and nasty? It does seem as if my c-clips are too small for my new lines. Please chime in Quote Link to comment Share on other sites More sharing options...
Big Mark Posted May 22, 2014 Share Posted May 22, 2014 I have HEL lines and the C-clip doesn't fit that well at all. I think I made it fit the best I could. Quote Link to comment Share on other sites More sharing options...
prosty Posted May 22, 2014 Author Share Posted May 22, 2014 I tried to push the pressure clip onto the hose but that just bent the clip so I guess I'll just make a two clips of my own, too bad, really nice connetors and banjos otherwise. I'd gone with goodridge had I known the fitment would be this rubbish with the HEL ones:). With the c-clip it would still rub and not sit snug in the holder so I'm putting a hose tie on them instead. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted May 23, 2014 Share Posted May 23, 2014 I found equivalent Goodrich ones to be a lot more expensive. HEL connecters are stainless where Goodridge are Zinc coated for the same price, you need to pay more for the fully stainless Goodrich kit. Maybe contact HEL to let them know that they have an issue with their kit. Quote Link to comment Share on other sites More sharing options...
prosty Posted May 23, 2014 Author Share Posted May 23, 2014 Yes the price I paid for my HEL Lines was 69 quid + shipping so it was very cheap Quote Link to comment Share on other sites More sharing options...
Shane Posted May 23, 2014 Share Posted May 23, 2014 I wasn't too impressed with the Hel kit to be honest, I found it very hard to dress/position the rear ones in a way that they wouldn't foul on the inner edge of the rears wheels. It was the way they had been assembled, ie. the position of the banjo in relationship to the position to the flats at the other end. To get both ends in place without putting loads of twist strain on the flexi at the same time as getting the pipes to a form that didn't rub on the inner edge of the wheel was bit of a mission. One side was much worse than the other. Oddly, I had no problem with the clip fittings, they were fine on mine, and I should add that the front ones were fine. Does raise a few concerns re their QC though. Quote Link to comment Share on other sites More sharing options...
prosty Posted May 23, 2014 Author Share Posted May 23, 2014 Yeah I noticed that you had to make sure the rear lines won't touch the wheels but I'm pretty sure I got that taken care of. Quote Link to comment Share on other sites More sharing options...
prosty Posted May 24, 2014 Author Share Posted May 24, 2014 Sorted. I bought a set of 4 generic clips with larger mouth and I got it to fit real snug. Cost me ~7 quid extra . Happy with the result, looks like stock fitment now Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted May 25, 2014 Share Posted May 25, 2014 I've fitted Goodrich all round on mine and had the same issue. The fronts fit exactly as stock, but the rear knuckles that sit in the bracket for the C-clip are not even close! Quote Link to comment Share on other sites More sharing options...
Big Mark Posted May 26, 2014 Share Posted May 26, 2014 Sorted. I bought a set of 4 generic clips with larger mouth and I got it to fit real snug. Cost me ~7 quid extra . Happy with the result, looks like stock fitment now Can you post a link to where you got your clips from? Quote Link to comment Share on other sites More sharing options...
prosty Posted May 26, 2014 Author Share Posted May 26, 2014 I bought a set from a local dealer here in Sweden This is the one http://www.mekonomen.se/bil/reservdelar/bromssystem/bromsslang/clips-for-bromsslang-ps486a23890sv (~3.5 GBP each) You should just go into the local parts shop with a stock clip and ask them to find a 1-2mm bigger mouth clip. Or just grind them a bit with a course file. I had to turn the front lines so they wouldn't slide through the hole of the holder so that the edge of the 17mm socket head was against the holder so the clip could press down the line against the holder. (lots of repetion of names here ) Not easy to explain but it works. I've tried to twisting pulling and bending the lines , and they won't budge a mm so it sits really tight now. Quote Link to comment Share on other sites More sharing options...
Mugello Posted May 26, 2014 Share Posted May 26, 2014 Sorted. I bought a set of 4 generic clips with larger mouth and I got it to fit real snug. Cost me ~7 quid extra . Happy with the result, looks like stock fitment now I also run the HEL stainless steel hoses and have no issue what so ever. Im guessing you are refering to the clips in the below link ? http://www.ebay.co.uk/itm/HEL-Performance-Brake-Hose-Retaining-Clips-4-Pack-/330941969953?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4d0dadb621 Hel sell them on there own. I run these clips and they work perfectly Quote Link to comment Share on other sites More sharing options...
prosty Posted May 26, 2014 Author Share Posted May 26, 2014 Nice Find Mugello. Though the HEL lines doesn't fit as stock but with these you can make it work by using your head a bit Maybe I'll buy these just to be safe too thanks! Quote Link to comment Share on other sites More sharing options...
slow8dirty Posted May 26, 2014 Share Posted May 26, 2014 Mugello, Very good find. Quote Link to comment Share on other sites More sharing options...
Richie_k83 Posted May 26, 2014 Share Posted May 26, 2014 Never tend to hear good things about Hel hoses being s good fit, definitely quite cheap though. SFS now build most Hel kits that are sold in the UK not that it means much Quote Link to comment Share on other sites More sharing options...
Mugello Posted May 28, 2014 Share Posted May 28, 2014 Nice Find Mugello. Though the HEL lines doesn't fit as stock but with these you can make it work by using your head a bit Maybe I'll buy these just to be safe too thanks! Mugello, Very good find. Your welcome guys n girls Never tend to hear good things about Hel hoses being s good fit, definitely quite cheap though. SFS now build most Hel kits that are sold in the UK not that it means much With these clips my HEL lines fit perfect (I have made all custom new brake lines) but they fit stock fine Quote Link to comment Share on other sites More sharing options...
