Guest giannakis Posted May 22, 2014 Share Posted May 22, 2014 Hello guys i own an SZ-R Toyota supra with a 2JZGE Motor and a V161 6 speed manual transmission. I want to buy a new clutch kit but i am not sure which one would work because i called Toyota and they said they dont have the SZ-R model registered in their database and they dont know... Anyone here experienced the same issue before? I see that all non turbo clutch kits are for 5 speed transmissions but mine is 6 speed from factory and i dont know what flywheel i ve got. Quote Link to comment Share on other sites More sharing options...
Zeiretto Posted May 22, 2014 Share Posted May 22, 2014 It's the same box as the facelift 6 speed Twin Turbo models so you can get a clutch for that (please correct me if I'm wrong!). Quote Link to comment Share on other sites More sharing options...
Guest giannakis Posted May 22, 2014 Share Posted May 22, 2014 It's the same box as the facelift 6 speed Twin Turbo models so you can get a clutch for that (please correct me if I'm wrong!). I know that the clutch kit for turbo models would fit the gearbox but would it feet the flywheel? Quote Link to comment Share on other sites More sharing options...
Benjy Posted May 22, 2014 Share Posted May 22, 2014 Yes. Quote Link to comment Share on other sites More sharing options...
Guest giannakis Posted May 22, 2014 Share Posted May 22, 2014 Yes. But how do u know? Quote Link to comment Share on other sites More sharing options...
Benjy Posted May 22, 2014 Share Posted May 22, 2014 Because I do. Quote Link to comment Share on other sites More sharing options...
Guest giannakis Posted May 22, 2014 Share Posted May 22, 2014 Because I do. do u know what flywheel my car has? Quote Link to comment Share on other sites More sharing options...
Benjy Posted May 22, 2014 Share Posted May 22, 2014 Is it a standard NA 6 speed? Quote Link to comment Share on other sites More sharing options...
Guest giannakis Posted May 22, 2014 Share Posted May 22, 2014 Is it a standard NA 6 speed? Its a 2JZGE with a V161 gearbox. 6 speed Quote Link to comment Share on other sites More sharing options...
Style Posted May 22, 2014 Share Posted May 22, 2014 I've got an SZ-R 6spd NA and I fitted a Chris Wilson 6spd clutch. It's an uprated TT clutch, works perfectly. Quote Link to comment Share on other sites More sharing options...
Guest giannakis Posted May 22, 2014 Share Posted May 22, 2014 I've got an SZ-R 6spd NA and I fitted a Chris Wilson 6spd clutch. It's an uprated TT clutch, works perfectly. So do u think the Toyota's factory turbo clutch kit would fit my na? Quote Link to comment Share on other sites More sharing options...
Nic Posted May 22, 2014 Share Posted May 22, 2014 (edited) So do u think the Toyota's factory turbo clutch kit would fit my na? Yes. These are the Toyota part numbers for the standard 6spd 2JZGE/2JZGTE clutch, the flywheel and clutch are the same on the NA and TT 6psd. Edited May 22, 2014 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest giannakis Posted May 22, 2014 Share Posted May 22, 2014 Yes. These are the Toyota part numbers for the standard 6spd 2JZGE/2JZGTE clutch, the flywheel and clutch are the same on the NA and TT 6psd. http://i60.tinypic.com/21jamvo.jpg Where have u found this source sir? Quote Link to comment Share on other sites More sharing options...
Benjy Posted May 22, 2014 Share Posted May 22, 2014 I give up. Quote Link to comment Share on other sites More sharing options...
Style Posted May 22, 2014 Share Posted May 22, 2014 If there is a single member on this forum who's word is gospel it's Nic's. It'll be directly from the Toyota database or something similar I'd imagine Quote Link to comment Share on other sites More sharing options...
Nic Posted May 22, 2014 Share Posted May 22, 2014 (edited) Where have u found this source sir? The pic is from the Toyota EPC (Electronic Parts Catalogue) Edited May 22, 2014 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 22, 2014 Share Posted May 22, 2014 Also it's "you", not "u" Quote Link to comment Share on other sites More sharing options...
Abz Posted May 22, 2014 Share Posted May 22, 2014 Where have u found this source sir? His made it up... Only joking! I have an SZ-R & I just put a stock TT clutch, no difference. Quote Link to comment Share on other sites More sharing options...
