SupraStar 3000 Posted May 21, 2014 Share Posted May 21, 2014 Its been awhile, but I'm pretty sure it was more accessible on the NA. On this TT, No matter which angle I go in at, I can't get my moneky arms in enough to reach! How are you guys getting to the filter? Link to comment Share on other sites More sharing options...
Benjy Posted May 21, 2014 Share Posted May 21, 2014 Is this just to take the heat off your boot release thread? Link to comment Share on other sites More sharing options...
David P Posted May 21, 2014 Share Posted May 21, 2014 Link to comment Share on other sites More sharing options...
Shane Posted May 21, 2014 Share Posted May 21, 2014 It's not quite as easy on the TT Ed. Ian C did a write up I think about how to do it using carrier bags to limit the spillage. But you can do it but weaving your arm in from the top, its a tight squeeze but can be done. best to drain the oil a good while before you plan to do it so as much as poss has drained from the old one before you unscrew it. Link to comment Share on other sites More sharing options...
Graham1984 Posted May 21, 2014 Share Posted May 21, 2014 Link to comment Share on other sites More sharing options...
Axl Posted May 21, 2014 Share Posted May 21, 2014 Link to comment Share on other sites More sharing options...
David P Posted May 21, 2014 Share Posted May 21, 2014 Is that one, "The Dangers of Bottom Fondling"? Link to comment Share on other sites More sharing options...
Graham1984 Posted May 21, 2014 Share Posted May 21, 2014 Is that one, "The Dangers of Bottom Fondling"? It's handy when in a large crowd Link to comment Share on other sites More sharing options...
Benjy Posted May 21, 2014 Share Posted May 21, 2014 On a serious note Ed... This is the tool I'd use... Link to comment Share on other sites More sharing options...
Graham1984 Posted May 21, 2014 Share Posted May 21, 2014 [ATTACH=CONFIG]186025[/ATTACH] You and Supraleeturbo will get on like a house on fire. Link to comment Share on other sites More sharing options...
Benjy Posted May 21, 2014 Share Posted May 21, 2014 You and Supraleeturbo will get on like a house on fire. Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted May 21, 2014 Author Share Posted May 21, 2014 Thanks Shane. Maybe I'll try after moving the diagnostics plug and pulling aside a few wires. You guys must have really small arms,... or quit masturbation wayyy to soon in life. Link to comment Share on other sites More sharing options...
Axl Posted May 21, 2014 Share Posted May 21, 2014 My last attempt of filter removal did not go to plan Link to comment Share on other sites More sharing options...
Graham1984 Posted May 21, 2014 Share Posted May 21, 2014 [ATTACH=CONFIG]186027[/ATTACH] My last attempt of filter removal did not go to plan That's normally how I arrive at the pub. Link to comment Share on other sites More sharing options...
Havard Posted May 21, 2014 Share Posted May 21, 2014 Grab it firmly with one of your wanking spanners and give it a right good tug. For the oil filter I have no idea..!! Link to comment Share on other sites More sharing options...
Graham1984 Posted May 21, 2014 Share Posted May 21, 2014 Grab it firmly with one of your wanking spanners and give it a right good tug. For the oil filter I have no idea..!! Link to comment Share on other sites More sharing options...
Axl Posted May 21, 2014 Share Posted May 21, 2014 Grab it firmly with one of your wanking spanners and give it a right good tug. For the oil filter I have no idea..!! 97....98.....99 ftlbs and change hands Link to comment Share on other sites More sharing options...
Scooter Posted May 21, 2014 Share Posted May 21, 2014 I don't really want to spoil the fun! But Ed you need to take out the 3 10mm power steering reservoir bolts then you can gently lift it up and away to allow you to reach in with your right hand and take a firm grip. Remember in this instance you finish and don't start with lubrication! Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted May 21, 2014 Author Share Posted May 21, 2014 I don't really want to spoil the fun! But Ed you need to take out the 3 10mm power steering reservoir bolts then you can gently lift it up and away to allow you to reach in with your right hand and take a firm grip. Remember in this instance you finish and don't start with lubrication! See,... this is the response I was looking for. Knew they'd be a technique. Much appreciated mate. The rest of you should be asshamed Link to comment Share on other sites More sharing options...
rob_sri Posted May 21, 2014 Share Posted May 21, 2014 This was going as well as the boot release thread for a minute there .. Link to comment Share on other sites More sharing options...
Benjy Posted May 21, 2014 Share Posted May 21, 2014 See,... this is the response I was looking for. Knew they'd be a technique. Much appreciated mate. The rest of you should be ass hamed What's Ass hamed when it's at home? Lol Link to comment Share on other sites More sharing options...
Graham1984 Posted May 21, 2014 Share Posted May 21, 2014 What's Ass hamed when it's at home? Lol Where is Lee Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted May 21, 2014 Author Share Posted May 21, 2014 I've learnt allot about car mechanics since those early days. Errm,... can't think of an example right now though! Link to comment Share on other sites More sharing options...
Graham1984 Posted May 21, 2014 Share Posted May 21, 2014 I've learnt allot about car mechanics since those early days. Errm,... can't think of an example right now though! Just keep it simple Ed.. Key+door+open=success. Link to comment Share on other sites More sharing options...
