anyone know the part code for the vvti tiptronic radiator?
qaisar
Dont know what the prob is exactly but rads can be recored (rebuilt) maybe not if you have driven into a solid object like a wall!:p And depending on the replacement cost from Toyota you may want to consider a Fluidline rad which some of the guys with quick Supras seem to use......
thanks for the replys guys, the reason i ask is i need a replacement. thought about the fluidynwe and pwr ones but they cost about 700 once everything is taken into account. so im getting a new one made buy dudersvr which should perform better than the stock. only prob is need to know if it is like the manual or like me and chris wilson suspect like the auto, or entirely different.
darren could u have a look at yours, chris says it should have it stenciled in grey or white on the radiator.
a) No one re-cores Supra Rads...been there tried that
b) The Tiptronic is an auto...so I would assume it has an auto's cooler in the rad. FWIW I fitted a stock auto rad to my 6-spd car (cause toyota fcuked up and them proceeded to blame me) and all is ok. To find out if you have an auto's rad you need to look down inside the fan shroud to the bottom of the rad and look for 2x 1/2 inch pipes coming out of the bottom tank.
c) How the hell does a Fluidyne cat that much?!!! Terry got his in for about £500 fitted AFAIK (Terry pls correct me if it was more expensive) unless your suggesting it would cost an extra £200 for an additional trans cooler to be fitted and rigged up? It's not hard to fit a rad so you can waive fitting costs...doing it yourself is a piece of pi$$.
d) Docking Engineering were recommended to me by CW when I was looking into custom replacements.
sorry meant darren with the vvti, also if u do check please take note of what alex has said at b
alex yeah i was talking about after vat and with the transmission cooler, but il check with terry all the same
Alex, mine I think was re-cored as the warrenty would not pay for a new one when it sprang a leak.
Apparently (acorgind to the garage that did the work) their supplier kept sending Soarer radiators.....
It's got a sticker on it, I'll try and see if it's still readable (if I ever see my car in daylight)
yeah darren thats what it says on the site, use steroids ;)
nah but ur right to an extent, depends on ur goals, if u wanna be huge u need steroids, but otherwise u can get by without.
its just something im trying for myself at the moment to see how it goes, gotten out of shape since i left law school
Guest Martin F
Originally posted by Syed Shah
Remember that the facelifts had copper rads, while the pre-facelifts had aluminium rads AFAIK.
Other way around i think Syed.
  • 3 weeks later...
thanks to darren for checking out his radiatior.
this is what he saw on the top of it, but i havent been able to find out if it is the same as the auto or not
in white lettering: Toyota 4643 422171-3761 with a big Q on the side
in raised leterring: SAE PA66 PA66-GF25
he said he could see a hose on the left side but couldnt see round the right side
anybody know the answer?
if so could you let me or john (dudersvr) know cos im getting one made up through him, cheers
