zaheer0027 Posted May 20, 2014 Share Posted May 20, 2014 I have a 94 na j spec with the small brakes 2p/1p. Are there any lexus brakes that have the exact same setup? Reason I'm asking is I need pads very badly and it is very difficult to get them, ebc etc, in South Africa. Also very expensive. Importing them myself is also prohibitively expensive just for pads. It would be much easier and cheapest to get a lexus model which is readily available in our market. I have searched and could only find "ifs" "buts" "looks like" etc. Please only offer advice if you are 100% certain. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 20, 2014 Share Posted May 20, 2014 Have a look on here, it might show you if any pads are the same http://www.mintex.co.uk Quote Link to comment Share on other sites More sharing options...
Dan_Turism0 Posted May 20, 2014 Share Posted May 20, 2014 (edited) i suspect the IS200 front pads are the same the carriers and calipers are certainly similar Edited May 20, 2014 by Dan_Turism0 (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris88 Posted May 20, 2014 Share Posted May 20, 2014 According to the EPC the rear pads are the same as a 93-97 GS300 but the fronts are unique to the JDM Supra. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 20, 2014 Share Posted May 20, 2014 According to the EPC the rear pads are the same as a 93-97 GS300 but the fronts are unique to the JDM Supra. There are diagrams here of the brake pads that may help http://www.mkivsupra.net/vbb/showthread.php?249089-Supra-Brake-setups Quote Link to comment Share on other sites More sharing options...
garethr Posted May 20, 2014 Share Posted May 20, 2014 (edited) Front: GS300 Mk1 GS300/GS400/GS430 Mk2 IS200 IS300 and the middle version of the LS400, I think (small brakes on the early ones, bigger 4-pots on the later ones) Rear: GS300 Mk1 OE pads may have different part nos for different compounds. Edited May 20, 2014 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
zaheer0027 Posted May 21, 2014 Author Share Posted May 21, 2014 Excellent Thank you kind sirs ! I will do a change and confirm the results Quote Link to comment Share on other sites More sharing options...
David P Posted May 21, 2014 Share Posted May 21, 2014 Any minor difference in the backing plate could soon be sorted with an angle grinder. Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 21, 2014 Share Posted May 21, 2014 Excellent Thank you kind sirs ! I will do a change and confirm the results Can you not pop the pads out and take to your supplier to match them up Quote Link to comment Share on other sites More sharing options...
