Supra TT Throttle Cable Replacement (Question)
MattP
Hi guys I recently noticed that my accelerator cable was slack on the throttle body even at full adjustment, on further inspection it appears a small rubber bump stop looking part has split and is failing to keep tension on the cable from the inside of the car.
the piece in question is part of the throttle cable and it is attached at the interior pedal assembly I have temporarily fixed the problem but its now on borrowed time thus my question is this...
Is the throttle cable for the NON VVTI 2JZGTE the same as the VVTI 2JZGTE as im aware the throttles are slightly different.
and if any of you know a rough price or link It would be appreciated. :)
Edited by MattP (see edit history)
