W58 to Getrag conversion parts
listy
Yeah. Do a burn out. If you leave 1 line, it's an open diff, if you leave 2 it's an LSD.
Then look at the size of the casing (pics should do to see which diff it is...). If it's small with 1 line, A01A/A02A, small with 2 lines, A01B/A02B LSD.
Also, which flange has it got, 3 or 4 bolt?
What numbers havd you got on the VIN plate fir the diff?
David P will probably be able to tell you just by seeing it.
