Guest Kevderby Posted May 17, 2014 Share Posted May 17, 2014 Hi guys need ya expertise, I've had battery issues so decided to get new one from euro car parts I went to fit onto my supra and just as I realised the posts was too small then noticed that the terminals was back to front also!!! So before I knew it the terminals had arked across the battery!! So know I've got no power going into the car I found two fuses in engine bay blown which I've replaced but I seem to get no power on any permanent fuses in the kick panel have no ignition lights or even central locking and alsorts it seems that there's power in engine bay but nothing going into the fuse box in kick panel Any help would be hugely appreciated thanks Kev Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted May 17, 2014 Share Posted May 17, 2014 Jesus christ, I'm sure someone far more useful than me will be along shortly to help you out. Have you now fitted the battery in the correct manner? Using a volts meter is it reading anything at all? When I read the title i thought it was another poor sod that just brought a NA Quote Link to comment Share on other sites More sharing options...
Guest Kevderby Posted May 17, 2014 Share Posted May 17, 2014 I've had the car 12 years loved it it was just one of those silly things and thinking that they gave me the right battery so didn't just check and just got on with it doh I've fitted a battery now just to get me sorted but just can't believe it Quote Link to comment Share on other sites More sharing options...
kitch79 Posted May 17, 2014 Share Posted May 17, 2014 He did See the new member thread few threads down :-) Quote Link to comment Share on other sites More sharing options...
Scott Posted May 17, 2014 Share Posted May 17, 2014 Its the 120A fuse that's gone mate. You need to split the fusebox apart (3 nuts, one under the red flap marked +). You can then unbolt it from underneath to replace it. - - - Updated - - - Jesus christ, I'm sure someone far more useful than me will be along shortly to help you out. Have you now fitted the battery in the correct manner? Using a volts meter is it reading anything at all? When I read the title i thought it was another poor sod that just brought a NA Bought!!!!!! Quote Link to comment Share on other sites More sharing options...
Guest Kevderby Posted May 17, 2014 Share Posted May 17, 2014 I'm sure I checked it or is that one not accessible so that's why your telling me to split the fuse box and thanks for the help Scott Cheers Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted May 17, 2014 Share Posted May 17, 2014 Bought!!!!!! I've been drinking Quote Link to comment Share on other sites More sharing options...
Scott Posted May 17, 2014 Share Posted May 17, 2014 I've been drinking I let the one the other day go! Don't let it happen again - - - Updated - - - I'm sure I checked it or is that one not accessible so that's why your telling me to split the fuse box and thanks for the help Scott Cheers You can visually check it. It's a huge white one with a clear cover over it with 120A embossed on it. If you look inside, it'll be blown. Takes a bit of fettling to get it out, so take your time. It's straight forward enough Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted May 17, 2014 Share Posted May 17, 2014 I let the one the other day go! Don't let it happen again *Off to check previous mistake* Missed the F on finger the other day, Can't be arsed to look back any further so you can go uck yourself Quote Link to comment Share on other sites More sharing options...
Guest Kevderby Posted May 17, 2014 Share Posted May 17, 2014 So it's not one I checked then I know I checked the 50amp ones fingers crossed and will check it in Morning thanks for you help Scott let you know how I get on cheers Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 18, 2014 Share Posted May 18, 2014 Here you go Kev Quote Link to comment Share on other sites More sharing options...
Guest Kevderby Posted May 18, 2014 Share Posted May 18, 2014 Thanks for the help guys I've taken the fuse out and was blown as Scott said I will get a new one in morning but still got a feeling something else is a miss but until I've replaced the fuse I won't know Cheers kev Quote Link to comment Share on other sites More sharing options...
dodec j Posted May 18, 2014 Share Posted May 18, 2014 You can only get one from Toyota dealer mate just in case you didn't know Quote Link to comment Share on other sites More sharing options...
Scott Posted May 18, 2014 Share Posted May 18, 2014 Thanks for the help guys I've taken the fuse out and was blown as Scott said I will get a new one in morning but still got a feeling something else is a miss but until I've replaced the fuse I won't know Cheers kev It all depends on your luck mate. I did it many moons ago and all that was wrong was the 120A fuse. When that goes... nothing at all works. If you are unlucky, the ignitor may be cooked. Other than that, everything should be fine. Quote Link to comment Share on other sites More sharing options...
Guest Kevderby Posted May 19, 2014 Share Posted May 19, 2014 hi scott ive replaced the 120amp fuse some things have kicked in like my alarm but I still get no type of ignition feed, so is this the ignitor u mentioned and can u tell me where it is and do I have to replace etc... cheers kev Quote Link to comment Share on other sites More sharing options...
Guest Kevderby Posted May 19, 2014 Share Posted May 19, 2014 scrap that its working fine I unplugged the connector from behind the key switch in car many thanks guys for all help and info kev Quote Link to comment Share on other sites More sharing options...
Scott Posted May 19, 2014 Share Posted May 19, 2014 Glad it's working Quote Link to comment Share on other sites More sharing options...
