listy Posted May 17, 2014 Share Posted May 17, 2014 This is just for confirmation really, I can never remember what smoke is for what Symptoms -Blue smoke from the exhaust (Tayfun.tugra pointed it out on the way to JapFest) -Oil residue in the IC pipes No problems on boost or normal driving, oil level not really affected. I change my oil every 3-4 months and have never had to top it up (daily driver) So, am I right in thinking this is my turbo oil seals on their way out? If so, over the next few months I'll probably be looking for a pair of low (ish) mileage stock turbos. Quote Link to comment Share on other sites More sharing options...
kitch79 Posted May 17, 2014 Share Posted May 17, 2014 Blue smoke is what I have, think it was the last thread I created, but I thought it was some other oil seal. After raising the thread and speaking to Jurgen, all points to turbo seals on mine :-( Getting worse too! Quote Link to comment Share on other sites More sharing options...
kitch79 Posted May 17, 2014 Share Posted May 17, 2014 http://www.mkivsupra.net/vbb/showthread.php?t=307335 That thread - hopefully... I'm on tapatalk. Quote Link to comment Share on other sites More sharing options...
Chris88 Posted May 17, 2014 Share Posted May 17, 2014 If it lasts beyond the first few minutes of running it's odds-on turbo seals. Quote Link to comment Share on other sites More sharing options...
charlton Posted May 17, 2014 Share Posted May 17, 2014 Blue smoke is usually VSS and white smoke is turbo seals - I have both... Quote Link to comment Share on other sites More sharing options...
Sheefa Posted May 18, 2014 Share Posted May 18, 2014 Listy does it clear after a short while? If so then it has to be valve stem seals. If it doesn't then yep turbo seals are in need of replacing. Any severe smoke under boost? When Turbofit buggered my car and the turbo seals it was pluming white smoke under boost. Quote Link to comment Share on other sites More sharing options...
Tsia Posted May 18, 2014 Share Posted May 18, 2014 Listy does it clear after a short while? If so then it has to be valve stem seals. If it doesn't then yep turbo seals are in need of replacing. Any severe smoke under boost? When Turbofit buggered my car and the turbo seals it was pluming white smoke under boost. Other way around for me (sort of.) It wouldn't smoke under boost, but would smoke on lift off. Turbo seals done, all better. Quote Link to comment Share on other sites More sharing options...
kitch79 Posted May 18, 2014 Share Posted May 18, 2014 Other way around for me (sort of.) It wouldn't smoke under boost, but would smoke on lift off. Turbo seals done, all better. Similar to my issue. How much did it cost to have them done? Quote Link to comment Share on other sites More sharing options...
Tsia Posted May 18, 2014 Share Posted May 18, 2014 Similar to my issue. How much did it cost to have them done? I got them done at a garage in Yorkshire (long story) who did the labour of removing the turbos, plus rebuilds etc for ~£1300 or so, I think. Turns out my turbos were completely knackered and needed a lot more than just the seals doing too, which brought the price up. Quote Link to comment Share on other sites More sharing options...
kitch79 Posted May 18, 2014 Share Posted May 18, 2014 I got them done at a garage in Yorkshire (long story) who did the labour of removing the turbos, plus rebuilds etc for ~£1300 or so, I think. Turns out my turbos were completely knackered and needed a lot more than just the seals doing too, which brought the price up. Cheers... Ouch ha. I was quoted 1000, max worse case scenario 1500! I was hoping you'd say 500 haha. It's the time without the car that'll kill me more, it's more only one. Quote Link to comment Share on other sites More sharing options...
listy Posted May 18, 2014 Author Share Posted May 18, 2014 Cheers... Ouch ha. I was quoted 1000, max worse case scenario 1500! I was hoping you'd say 500 haha. It's the time without the car that'll kill me more, it's more only one. You can buy a pair for £250 ish. Replace them yourself Probably what I'll be doing, then rebuild the old ones, ready for when the replacements go Quote Link to comment Share on other sites More sharing options...
kitch79 Posted May 18, 2014 Share Posted May 18, 2014 Hmmm. Not sure if I'd trust myself How much ya talking for brand new turbos from Mr T? Quote Link to comment Share on other sites More sharing options...
Tsia Posted May 18, 2014 Share Posted May 18, 2014 It takes a proper garage a fair few hours to change them, so I didn't trust myself doing it - not to mention I didn't want to risk 2nd hand turbos going again Brand new from Mr T? No chance Quote Link to comment Share on other sites More sharing options...
Sanya Posted May 18, 2014 Share Posted May 18, 2014 A proper garage does not imply a proper mechanic is working on your car bud, also someone elses car is always treated not like your own. If you have enough info and have someone from the club to help you I am sure to change the turbo is not rocket science. Time on the other hand is everything.. so If you have time it is better to replace it yourself. Quote Link to comment Share on other sites More sharing options...
Tayfun.tugra Posted May 18, 2014 Share Posted May 18, 2014 Every time you pulled off from a stand still a small puff of blue smoke would come out, nothing when driving, didn't see any white smoke at the time. Hope it helps. Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 19, 2014 Share Posted May 19, 2014 Sounds like how mine started Jon. On boost it's fine but on lift off it smokes blue, and if I touch the throttle again it plumes out the back! Ask the dragonballer's, I smoked plenty of them this weekend! What boost you running at the moment? Quote Link to comment Share on other sites More sharing options...
