Help with fitting a trickle charger
Heyrick
Hi,
I would like to fit a trickle charger so that I can access the connection in the cabin - anyone know a reliable 'live' connection that I can connect to, either under the dash or even better, around the hand brake area? Or will I have to run a wire from the battery?
Thanks for any help!
DIN socket in the dash connected to the battery (with an inline fuse at the battery end) and a matching DIN plug connected to the charger.
Or rewire the cigarette lighter socket so that it's always live and plug the charger into it.
What charger do you use? CTEK sell a little panel with a socket and battery condition indicator LEDs. You could probably use it with any charger and a suitable plug.
http://www.vehicle-wiring-products.eu/VWP-onlinestore/switches/12vacc.php
http://www.ctek.com/gb/en/accessories/
Edited by garethr (see edit history)
