theredone Posted May 16, 2014 Share Posted May 16, 2014 Im currently building a na/t and need help on moving my power steering pump!! Does anyone have any useful info on how to do it and photos would help also Quote Link to comment Share on other sites More sharing options...
buster Posted May 16, 2014 Share Posted May 16, 2014 Pump or the res? Quote Link to comment Share on other sites More sharing options...
theredone Posted May 16, 2014 Author Share Posted May 16, 2014 Res because it will be in the way of the tt throttle body Quote Link to comment Share on other sites More sharing options...
theredone Posted May 20, 2014 Author Share Posted May 20, 2014 Anyone got any info on this? The res is in the way of my intercooler pipe, i am using a tt intake manifold on my na/t build Quote Link to comment Share on other sites More sharing options...
Al Massey Posted May 20, 2014 Share Posted May 20, 2014 You need a TT res. It's on a mounting bracket which moves it out of the way. Simple bolt on bolt off job Quote Link to comment Share on other sites More sharing options...
David P Posted May 20, 2014 Share Posted May 20, 2014 "Rummy" might have one for sale? http://www.mkivsupra.net/vbb/showthread.php?307946-Aluminium-power-steering-tank-(baffled) Quote Link to comment Share on other sites More sharing options...
theredone Posted May 20, 2014 Author Share Posted May 20, 2014 Thanks for the info, is the tt pump the same as the na pump? Quote Link to comment Share on other sites More sharing options...
David P Posted May 20, 2014 Share Posted May 20, 2014 (edited) You need a T.T. reservoir and it's 3 special bolts and the T.T. fluid hose and pump union. Pumps are same and the short bolt on the front of the N/A res mounting is correct size for T.T. hose union. As Al say's, it's plug & play. Edited May 20, 2014 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
theredone Posted May 20, 2014 Author Share Posted May 20, 2014 Okay dokey im pretty sure i can fabricate mine to same spec as the tt one or i could make an aluminium one at work Quote Link to comment Share on other sites More sharing options...
Chris88 Posted May 20, 2014 Share Posted May 20, 2014 Okay dokey im pretty sure i can fabricate mine to same spec as the tt one or i could make an aluminium one at work Either make a reservoir or buy a nice shiny chrome one. Quote Link to comment Share on other sites More sharing options...
