Crash Bandicoot Posted May 14, 2014 Share Posted May 14, 2014 Hi all, mates just recieved his turbokit from America. He will be on the forum shortly. He's got a stock na setup... The downpipe has 3 ports with threads for lambda sensors. On my na-t kit the downpipe has the same ports but the bottom is blanked. Can you use the oem oxygen/lambda sensors? Do we blank the bottom on his downpipe? Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted May 14, 2014 Author Share Posted May 14, 2014 It is an xs power kit Quote Link to comment Share on other sites More sharing options...
Chris88 Posted May 14, 2014 Share Posted May 14, 2014 It would depend on what kind of engine management you plan to use, however it's always better (AFAIK anyway) to use a wideband sensor. Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 14, 2014 Share Posted May 14, 2014 exactly that depends on what ecu your going with , Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted May 14, 2014 Author Share Posted May 14, 2014 What's the options? Quote Link to comment Share on other sites More sharing options...
Chris88 Posted May 14, 2014 Share Posted May 14, 2014 What's the options? Basic choice is either piggy-back (where you keep the existing ECU) or stand-alone (which completely replaces the existing ECU). After that there are lots of options both ways. Cheapest option is piggy-back (especially if you have an auto gearbox). Quote Link to comment Share on other sites More sharing options...
Noz Posted May 15, 2014 Share Posted May 15, 2014 Can you explain better what the ports are. I only had 1 lamda sensor port and I have a bung for the wide band sensor as well. No idea why there is talk of changing ECU's just for this. I run OEM ECU with Piggy back and any other setup can use the standard OEM sensor port. Get some photos I think. Quote Link to comment Share on other sites More sharing options...
scott87 Posted May 16, 2014 Share Posted May 16, 2014 My downpipe has 3 ports. 2 are blanked off and one has a lambda sensor in. I have deleted one of the lambda sensors as running a piggyback and am not running a wideband. Quote Link to comment Share on other sites More sharing options...
