Guest Big red johnson Posted May 12, 2014 Share Posted May 12, 2014 I have a blitz bov fitted to my tt supra on the hard pipe going onto the inlet manifold, the pipe has a second outlet that the bov is attached to. I belive the stock bov is still fitted. Would there be any detrimental effects if I installed a hks bov where the stock one is? Quote Link to comment Share on other sites More sharing options...
girth45 Posted May 12, 2014 Share Posted May 12, 2014 No, mine was fitted where the stock one is. Just a tight fit and you will probably need the fitting kit. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Guest Big red johnson Posted May 12, 2014 Share Posted May 12, 2014 Thanks, silly question but if I was to also keep the blitz bov where it is and also fit the hks where the stock item is would this cause any side affects, I can't imagine it would seeing as it's just doing the same job the stock unit is doing. Quote Link to comment Share on other sites More sharing options...
Chris88 Posted May 12, 2014 Share Posted May 12, 2014 Thanks, silly question but if I was to also keep the blitz bov where it is and also fit the hks where the stock item is would this cause any side affects, I can't imagine it would seeing as it's just doing the same job the stock unit is doing. I don't think it would do any harm but TBH I can't see why you would want too non-linked BOV. If they're both working properly only one (the one with the lowest pre-load spring rate) will ever work. Quote Link to comment Share on other sites More sharing options...
