gavin.starr Posted May 12, 2014 Share Posted May 12, 2014 Only really just made a start on this as im waiting for the weather to get better and stop peeing it down. Removed the rad, aux belt, and battery etc... And got a few parts sprayed up at work ready for when it all goes back together again. Ive gone for a nice graphite grey as im going to get all my turbo hard pipes powder coated in a nice silver, so silver black and graphite gray is going to be the engine bay colour scheme. And thats as far as im up to at the moment, Hope to get the engine out within the week or 2 weather and time depending, And then get is shipped off down to Paul for a refresh/rebuild plus many other new parts. Gav Link to comment Share on other sites More sharing options...
ManwithSupra Posted May 12, 2014 Share Posted May 12, 2014 Look forward to the updates Link to comment Share on other sites More sharing options...
MattP Posted May 12, 2014 Share Posted May 12, 2014 Only really just made a start on this as im waiting for the weather to get better and stop peeing it down. Removed the rad, aux belt, and battery etc... http://i1154.photobucket.com/albums/p540/starrgavin/20140510_160948_zpsa90296fe.jpg And got a few parts sprayed up at work ready for when it all goes back together again. http://i1154.photobucket.com/albums/p540/starrgavin/20140512_151112_zpsc04888ec.jpg http://i1154.photobucket.com/albums/p540/starrgavin/20140512_151120_zps2cda5a27.jpg http://i1154.photobucket.com/albums/p540/starrgavin/20140512_151129_zps1dac8788.jpg Ive gone for a nice graphite grey as im going to get all my turbo hard pipes powder coated in a nice silver, so silver black and graphite gray is going to be the engine bay colour scheme. And thats as far as im up to at the moment, Hope to get the engine out within the week or 2 weather and time depending, And then get is shipped off down to Paul for a refresh/rebuild plus many other new parts. Gav It looks like your going for a similar look to what I just finished don't underestimate the cost of Stock Toyota gaskets and pipes lol And Good luck Link to comment Share on other sites More sharing options...
gavin.starr Posted May 12, 2014 Author Share Posted May 12, 2014 It looks like your going for a similar look to what I just finished don't underestimate the cost of Stock Toyota gaskets and pipes lol And Good luck I know what you mean about pipes, quite pricey. Link to comment Share on other sites More sharing options...
Suprash Posted May 12, 2014 Share Posted May 12, 2014 I just bought a full engine gasket set for my rebuild, came in at £800 odd Link to comment Share on other sites More sharing options...
Rich.2211 Posted May 12, 2014 Share Posted May 12, 2014 I just bought a full engine gasket set for my rebuild, came in at £800 odd I paid £280 for mine for a 2JZGE That was OEM Toyota including head gasket, front and rear crank seals etc. Link to comment Share on other sites More sharing options...
Kaan W Posted May 12, 2014 Share Posted May 12, 2014 I paid £280 for mine for a 2JZGE That was OEM Toyota including head gasket, front and rear crank seals etc. Think that's about what I payed for my genuine Toyota gasket set too. Good luck with the build Gav! Link to comment Share on other sites More sharing options...
The Raven Posted May 12, 2014 Share Posted May 12, 2014 Just got my from paul £280 Link to comment Share on other sites More sharing options...
MattP Posted May 12, 2014 Share Posted May 12, 2014 (edited) if that is all you wanted Suprash the full gasket kits are around £280 from Whifbitz. Edited May 12, 2014 by MattP (see edit history) Link to comment Share on other sites More sharing options...
gavin.starr Posted May 12, 2014 Author Share Posted May 12, 2014 Yea £280 is the one I'll be using off whifbitz. Link to comment Share on other sites More sharing options...
gavin.starr Posted May 13, 2014 Author Share Posted May 13, 2014 This is my shopping list as it stands Toyota 2JZ Crank Pulley Bolt Clevite 2JZ/1JZ Big End Bearing Set Clevite 2JZ/1JZ Main Bearing Set Clevite 2JZ/1JZ Thrust Washer Set ARP 2JZ/1JZ Main Stud Kit Toyota 2JZ-GTE Engine Gasket Kit Garage Whifbitz 2JZ Welded Crank Sprocket Toyota 2JZ/1JZ Crank Pulley Toyota 2JZ-GTE & 1JZ-GTE Water Pump TT Gates 2JZ Cambelt Toyota 2JZ Cambelt Tensioner Toyota 2JZ Cambelt Tensioner Pulley Toyota 2JZ-GTE Piston Ring Set Garage Whifbitz Aluminium Supra Radiator Toyota Supra Thermostat Garage Whifbitz 1.3 bar Rad Cap Toyota 2JZ-GTE Coil Pack Clip Garage Whifbitz 2JZ 264 Camshafts Syvecs S6 GP ECU Syvecs Supra 2JZ Loom Adaptor Pierburg Boost Control Solenoid Syvecs Cal Switch NTK Wideband O2 Sensor Syvecs Knock Sensor Syvecs Map Sensor Garage Whifbitz Fuel Pulsation Dampener Removal Hose Walbro 255LPH fuel pump kit Sard Injectors 2JZ-GTE & 1JZ-GTE Fitment Garage Whifbitz Supra Front Mount Intercooler Kit Garage Whifbitz 2JZ/1JZ Billet Engine Pulleys Garage Whifbitz 2JZ Idler Pulley AEM AFR Gauge Garage Whifbitz 2JZ/1JZ-GTE Coil Pack Set NGK Iridium Spark Plug Set Toyota Supra TT Cam Cover Breather Hoses Garage Whifbitz Silicon Rad Hoses Supra TT Plus a set of Pauls new Hybrids hopefully once its all finished off. Link to comment Share on other sites More sharing options...
The-Plethora Posted May 13, 2014 Share Posted May 13, 2014 Very nice job on the paint, very clean! I usually got through the process of clean it up a bit, spray it, realise it looks terrible then buy the same item new. Link to comment Share on other sites More sharing options...
Suprash Posted May 14, 2014 Share Posted May 14, 2014 if that is all you wanted Suprash the full gasket kits are around £280 from Whifbitz. They aint fella, I got my discounted through Tim (TB Developments), mine included full engeine gasket set, inlet and all exhaust gaskets, head gasket, cam gaskets, even what looks like stem seals too, oil pickup o rings, every little fucking o ring you can think of, it dont sound like you boys have ordered what is properly known as a full engine gasket set, cause trust me, its hella more expensive then £280 lol. Link to comment Share on other sites More sharing options...
The Raven Posted May 14, 2014 Share Posted May 14, 2014 http://www.garagewhifbitz.co.uk/index.php/toyota-1099.html Is that not it? I dont want to ruin gavs build thread but it would be helpful to know if there is a 3rd gasket set Link to comment Share on other sites More sharing options...
Suprash Posted May 14, 2014 Share Posted May 14, 2014 http://www.garagewhifbitz.co.uk/index.php/toyota-1099.html Is that not it? I dont want to ruin gavs build thread but it would be helpful to know if there is a 3rd gasket set Yeah, that would appear to be it lol, just dont go buying a full piston ring set, mains, thrust and big end bearings on top then cause thats obviously what bumps it up to £800 lol, oh plus a new oil pump, that wont help ha Link to comment Share on other sites More sharing options...
gavin.starr Posted May 14, 2014 Author Share Posted May 14, 2014 Im not too fussed, I obviously have a budget which im quite tight on, and the rest will have to be purchased on a rolling monthly basis. I just want my engine spot on as I dont really want to be removing it again Link to comment Share on other sites More sharing options...
gavin.starr Posted July 1, 2014 Author Share Posted July 1, 2014 Not really been a lot of movement on this as ive been way too busy with other things. But i got a few things cleaned up at work. A few before and after pics Link to comment Share on other sites More sharing options...
gavin.starr Posted July 12, 2014 Author Share Posted July 12, 2014 Again ive been quite busy the last few weeks. But ive managed to get a fair bit done today, so hopefully the engine will soon be out. Some home made gate hinges I designed and built myself. Rocking some Abec 11 rollerblade ballbearing for smooth operation. New 100mm x 100mm post installed, fence panel cut along wit the concrete slab to suit the new post. A hanger on the house side. my newly welded and painted up frames. Facia boards painted and attached, should stop people from seeing whats going on up my drive. So today i got the supra jacked up nice and high to give me plenty of space to work underneath. Removed my HKS exhaust to discover lots of rot on the weld. With not enough meat to weld it up without melting through it. so looks like a new one is going to be required. I didnt take any more pics today but ive removed the PS pump, AC pump and all the pipe work associated with both, ecu wiring loom is out and al the cables unplugged. So hopefully tomorrow i shall unbolt everything underneath an pull the old girl out. Easier said than done lol. Gav Link to comment Share on other sites More sharing options...
LOGIE Posted July 13, 2014 Share Posted July 13, 2014 Nice work so far what type of paint did you use on the plastics? i.e spark plug cover Link to comment Share on other sites More sharing options...
gavin.starr Posted July 13, 2014 Author Share Posted July 13, 2014 Just normal 2k paint in graphite grey. Link to comment Share on other sites More sharing options...
gavin.starr Posted July 13, 2014 Author Share Posted July 13, 2014 Quick question for people that have removed their engines in the past. Whats the best height to have the car at. Obviously the gearbox needs to drop so the engine lifts at the front. My car is currently about 2 foot off the ground. Would it be better if I lowered the front and kept the rear elevated. Any help would be great as its all most ready to come out. Gav Link to comment Share on other sites More sharing options...
LOGIE Posted July 13, 2014 Share Posted July 13, 2014 Id say keep it level and raise it approx 18-24 inches at least. I had mine on railway sleepers which was a great help. Putting it back in is the real test youll need a small trolley jack to push the gearbox up whilst lower in the engine. Link to comment Share on other sites More sharing options...
gavin.starr Posted July 13, 2014 Author Share Posted July 13, 2014 Cool. Its about 2foot up now so should be ideal. Only the bonnet. Engine and gearbox mounts to go. See you on the other side Link to comment Share on other sites More sharing options...
gavin.starr Posted July 13, 2014 Author Share Posted July 13, 2014 Very busy day for me today. Prop shaft out. Everything unbolted and hoist moved into place. Lifting begins. all done for the day. I dont think ive done too bad considering ive been on my jack jones doing it all. My choice of shower gel this evening was er well swarfega lol. Link to comment Share on other sites More sharing options...
gavin.starr Posted July 14, 2014 Author Share Posted July 14, 2014 Where is going to be my best place to get replacement rubber hoses from for the ps resevoir,as ine were rock hard so I just crunched them up to remove it. Im going to be installing my greddy plenum so I may need to use some longer hoses to run the resevoir some where else in the engine bay. Gav Link to comment Share on other sites More sharing options...
