My project to return the supra back to the road begins
gavin.starr
Only really just made a start on this as im waiting for the weather to get better and stop peeing it down.
Removed the rad, aux belt, and battery etc...
And got a few parts sprayed up at work ready for when it all goes back together again.
Ive gone for a nice graphite grey as im going to get all my turbo hard pipes powder coated in a nice silver, so silver black and graphite gray is going to be the engine bay colour scheme.
And thats as far as im up to at the moment, Hope to get the engine out within the week or 2 weather and time depending, And then get is shipped off down to Paul for a refresh/rebuild plus many other new parts.
Gav
http://i1154.photobucket.com/albums/p540/starrgavin/20140510_160948_zpsa90296fe.jpg
http://i1154.photobucket.com/albums/p540/starrgavin/20140512_151112_zpsc04888ec.jpg
http://i1154.photobucket.com/albums/p540/starrgavin/20140512_151120_zps2cda5a27.jpg
http://i1154.photobucket.com/albums/p540/starrgavin/20140512_151129_zps1dac8788.jpg
Gav
It looks like your going for a similar look to what I just finished don't underestimate the cost of Stock Toyota gaskets and pipes lol
And Good luck
I paid £280 for mine for a 2JZGE :blink: That was OEM Toyota including head gasket, front and rear crank seals etc.
Think that's about what I payed for my genuine Toyota gasket set too.
Good luck with the build Gav!
This is my shopping list as it stands
Toyota 2JZ Crank Pulley Bolt
Clevite 2JZ/1JZ Big End Bearing Set
Clevite 2JZ/1JZ Main Bearing Set
Clevite 2JZ/1JZ Thrust Washer Set
ARP 2JZ/1JZ Main Stud Kit
Toyota 2JZ-GTE Engine Gasket Kit
Garage Whifbitz 2JZ Welded Crank Sprocket
Toyota 2JZ/1JZ Crank Pulley
Toyota 2JZ-GTE & 1JZ-GTE Water Pump TT
Gates 2JZ Cambelt
Toyota 2JZ Cambelt Tensioner
Toyota 2JZ Cambelt Tensioner Pulley
Toyota 2JZ-GTE Piston Ring Set
Garage Whifbitz Aluminium Supra Radiator
Toyota Supra Thermostat
Garage Whifbitz 1.3 bar Rad Cap
Toyota 2JZ-GTE Coil Pack Clip
Garage Whifbitz 2JZ 264 Camshafts
Syvecs S6 GP ECU
Syvecs Supra 2JZ Loom Adaptor
Pierburg Boost Control Solenoid
Syvecs Cal Switch
NTK Wideband O2 Sensor
Syvecs Knock Sensor
Syvecs Map Sensor
Garage Whifbitz Fuel Pulsation Dampener Removal Hose
Walbro 255LPH fuel pump kit
Sard Injectors 2JZ-GTE & 1JZ-GTE Fitment
Garage Whifbitz Supra Front Mount Intercooler Kit
Garage Whifbitz 2JZ/1JZ Billet Engine Pulleys
Garage Whifbitz 2JZ Idler Pulley
AEM AFR Gauge
Garage Whifbitz 2JZ/1JZ-GTE Coil Pack Set
NGK Iridium Spark Plug Set
Toyota Supra TT Cam Cover Breather Hoses
Garage Whifbitz Silicon Rad Hoses Supra TT
Plus a set of Pauls new Hybrids hopefully once its all finished off.
if that is all you wanted Suprash the full gasket kits are around £280 from Whifbitz.
They aint fella, I got my discounted through Tim (TB Developments), mine included full engeine gasket set, inlet and all exhaust gaskets, head gasket, cam gaskets, even what looks like stem seals too, oil pickup o rings, every little fucking o ring you can think of, it dont sound like you boys have ordered what is properly known as a full engine gasket set, cause trust me, its hella more expensive then £280 lol.
http://www.garagewhifbitz.co.uk/index.php/toyota-1099.html
Is that not it? I dont want to ruin gavs build thread but it would be helpful to know if there is a 3rd gasket set
Yeah, that would appear to be it lol, just dont go buying a full piston ring set, mains, thrust and big end bearings on top then cause thats obviously what bumps it up to £800 lol, oh plus a new oil pump, that wont help ha :D
  • 1 month later...
  • 2 weeks later...
Again ive been quite busy the last few weeks.
But ive managed to get a fair bit done today, so hopefully the engine will soon be out.
Some home made gate hinges I designed and built myself. Rocking some Abec 11 rollerblade ballbearing for smooth operation. :cool:
New 100mm x 100mm post installed, fence panel cut along wit the concrete slab to suit the new post.
A hanger on the house side.
my newly welded and painted up frames.
Facia boards painted and attached, should stop people from seeing whats going on up my drive.
So today i got the supra jacked up nice and high to give me plenty of space to work underneath.
Removed my HKS exhaust to discover lots of rot on the weld. With not enough meat to weld it up without melting through it. so looks like a new one is going to be required.
I didnt take any more pics today but ive removed the PS pump, AC pump and all the pipe work associated with both, ecu wiring loom is out and al the cables unplugged. So hopefully tomorrow i shall unbolt everything underneath an pull the old girl out.
Easier said than done lol.
Gav
Quick question for people that have removed their engines in the past. Whats the best height to have the car at. Obviously the gearbox needs to drop so the engine lifts at the front.
My car is currently about 2 foot off the ground. Would it be better if I lowered the front and kept the rear elevated.
Any help would be great as its all most ready to come out.
Gav
Id say keep it level and raise it approx 18-24 inches at least. I had mine on railway sleepers which was a great help. Putting it back in is the real test youll need a small trolley jack to push the gearbox up whilst lower in the engine.
Very busy day for me today.
Prop shaft out.
Everything unbolted and hoist moved into place.
Lifting begins.
all done for the day. I dont think ive done too bad considering ive been on my jack jones doing it all.
My choice of shower gel this evening was er well swarfega lol. :blink:
Where is going to be my best place to get replacement rubber hoses from for the ps resevoir,as ine were rock hard so I just crunched them up to remove it.
Im going to be installing my greddy plenum so I may need to use some longer hoses to run the resevoir some where else in the engine bay.
Gav
