Wide arch wheel question
Kendo11
Afternoon all.
I am soon to be fitting Veilside overfenders front and back, with the rears inparticular increasing the width by about 50-60mm.
I am relatively clued up on wheels, stud patterns centre bore etc, but what do I need to be searching for when looking for that extra width?
Or could I run it with spacers?? (heard bad things about those with bearings though).
Cheers
Buy a wider wheel :-) lol.
Don't want to tell you how to suck eggs, but...
If you have a 9.5" wide wheel with say 30 offset now (can be used no arch work)
Then get a 12" with with same offset. The wheel 1.25" further out AND in the arch
Get a 12" with 20 offset and it'll be 10mm out more than the previous 12" mentioned.
And so on.
As re spacers, I'd rather not use them, but if I had too, I'd buy the best I could.
As a rough guide front 9" +35 and rear 10" +35 will fit almost flush under the stock arches. So if you have 50mm wider arches and keep the same width wheels you would need the following offsets, 9" -15 and 10" -15, which is basically offset +35 - 50mm.
If you want different width wheels then use this offset calculator to work out the required offset.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
If I win some money/a long lost rich relative dies I'll be in touch.
Don't get me wrong yours are beautiful, I just think I've not thought this through properly haha.
265 existing on the rears so a high quality set of 40-50mm spacers should do it.
Haha, thanks. Wheels do cost a fair bit hence why alot of people chuck spacers behind their existing wheel.
What's the width and offset of your current wheel?
