Dave_harman1990 Posted May 11, 2014 Share Posted May 11, 2014 Hi people, really confused on this one, doing my timing belt and decided to change my 21year old water pump while I was at it. I got a blue print replacement which I was told is as good as oem, the bolts that hold it to the car are the right layout, but there is a hole on the top of the oem, which is at a 45 degrees angle on the blueprint where a hardpipe appears to go in, also on the blueprint on the underside there is what looks like a vacuum pipe nipple, which I could not find on the oem. Can someone tell me if im being an idiot or if this is the wrong part, ive looked and the blue print part number is correct for the twin turbo water pump 93 - 96 model :s Thanks in advance Quote Link to comment Share on other sites More sharing options...
Josh42 Posted May 11, 2014 Share Posted May 11, 2014 It's perfectly normal. my OEM one has it. I believe it's an overflow valve of some description Quote Link to comment Share on other sites More sharing options...
Dave_harman1990 Posted May 11, 2014 Author Share Posted May 11, 2014 How about the hole thats sitting at a 45 degree angle instead of flat on top? It looked like a hard pipe that goes into it so it won't be able to bend to fit on the side would it? Quote Link to comment Share on other sites More sharing options...
Dave_harman1990 Posted May 11, 2014 Author Share Posted May 11, 2014 this is how it should be by the blue print one isnt Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 11, 2014 Share Posted May 11, 2014 The pipe on the bottom is a dry drain, basically if coolant comes out of there, its toast. You should have just got one from Toyota but, the rear housing unbolts, just unbolt the pump from the housing, do the same on the car, sorted. Quote Link to comment Share on other sites More sharing options...
Dave_harman1990 Posted May 11, 2014 Author Share Posted May 11, 2014 I was debating that as an option, the important part would be changed so I didnt think/hope it would be an issue. Thanks for the advice people Quote Link to comment Share on other sites More sharing options...
