jdmjak Posted May 11, 2014 Share Posted May 11, 2014 doing an na-t build and want to lower the compression by using a thicker headgasket, will the standard gte headgasket fit right on to the ge engine? is it the same gasket just thicker? any help would be much appreciated cheers Quote Link to comment Share on other sites More sharing options...
Josh42 Posted May 11, 2014 Share Posted May 11, 2014 I've used the GTE gasket on mine. Works fine mate. Quote Link to comment Share on other sites More sharing options...
jdmjak Posted May 11, 2014 Author Share Posted May 11, 2014 brilliant will get one ordered then. cheers buddy!! much appretiated Quote Link to comment Share on other sites More sharing options...
Chris88 Posted May 11, 2014 Share Posted May 11, 2014 It will fit and will work fine but it's not as effective in terms of combusion efficiency as keeping the GE headgasket and fitting GTE pistons. Quote Link to comment Share on other sites More sharing options...
David P Posted May 11, 2014 Share Posted May 11, 2014 There has been many a discussion re. "squish", yet the N/A with T.T. gasket combo, in the real World has the squish purists proven otherwise. Quote Link to comment Share on other sites More sharing options...
