T14PPA Posted May 8, 2014 Share Posted May 8, 2014 Just been offered this turbo cheap. What you lot think? Any advice? Quote Link to comment Share on other sites More sharing options...
Noz Posted May 8, 2014 Share Posted May 8, 2014 Are you able to feel the shaft, to see if it has any radial play (angular movement left to right when sat in the bearing). Would be an indication. Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 8, 2014 Author Share Posted May 8, 2014 He said its new. Going to pick it up tomorrow so ill feel the shaft there. Just wanted to know if that turbo is good Quote Link to comment Share on other sites More sharing options...
David P Posted May 8, 2014 Share Posted May 8, 2014 You'll need to state the model/size(s) to stand a chance of a sensible answer, the label pic is ineligible. Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 8, 2014 Author Share Posted May 8, 2014 The guy dont know many details of the turbo. Anywhere on the turbo that says the info you need? Quote Link to comment Share on other sites More sharing options...
marc_p Posted May 8, 2014 Share Posted May 8, 2014 Old school, personally would stick to anti-surge turbos myself. Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted May 8, 2014 Share Posted May 8, 2014 Couple of things....It doesn't look new for a start. But if he says it is, why does he not have the details on it? Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 8, 2014 Author Share Posted May 8, 2014 Old school, personally would stick to anti-surge turbos myself. What do you mean by anti surge? Not boverd that its old school. Isit reliable? Will it produce good power? Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 8, 2014 Author Share Posted May 8, 2014 Couple of things....It doesn't look new for a start. But if he says it is, why does he not have the details on it? I thought the blades looked new? Maybe im wrong. Ive just messaged him to see if he has details Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 8, 2014 Share Posted May 8, 2014 It looks like an old diesel engine turbo off a (big) truck engine, and as such is totally unsuitable for a performance petrol engine. Apart from looking far too big it won't be designed for the exhaust gas temperatures a tuned petrol engine will have. Considereing the price of a good manifold, pipework, mappable ecu, mapping, engine rebuild, blah blah, you should be choosing the *correct* turbo for your needs, not a *cheap* turbo. IMHO.... Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 8, 2014 Author Share Posted May 8, 2014 Anyway of finding out if its a diesel turbo? I thought alot of the american supras use truck turbos with good results? I just thought for £130 for a genuine garrett turbo would be better then what im already running It looks like an old diesel engine turbo off a (big) truck engine, and as such is totally unsuitable for a performance petrol engine. Apart from looking far too big it won't be designed for the exhaust gas temperatures a tuned petrol engine will have. Considereing the price of a good manifold, pipework, mappable ecu, mapping, engine rebuild, blah blah, you should be choosing the *correct* turbo for your needs, not a *cheap* turbo. IMHO.... Quote Link to comment Share on other sites More sharing options...
David P Posted May 8, 2014 Share Posted May 8, 2014 The information on the label, or old wives prattle. Take your pick? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 8, 2014 Share Posted May 8, 2014 A Garrett agent, or Garrett themselves should be able to say what its original application was. The fact the Americans use them would be enough to send me running, to be honest Diesel engine turbos are NOT the same as petrol engine turbos. EGT's are vastly lower in diesels as they utilize the calorific content of the fuel far more efficiently. Quote Link to comment Share on other sites More sharing options...
mellonman Posted May 8, 2014 Share Posted May 8, 2014 here is a genuiene garrett diesel turbo on a supra for you Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 8, 2014 Author Share Posted May 8, 2014 here is a genuiene garrett diesel turbo on a supra for you Thats a bit extreme but i get the point. Im waiting to get info so i can hopefully rule out it being a diesel turbo Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted May 8, 2014 Share Posted May 8, 2014 £130 for a supposedly newish Garrett turbo sounds off putting. Quote Link to comment Share on other sites More sharing options...
David P Posted May 8, 2014 Share Posted May 8, 2014 Toyota used the same single turbo on 2LT 2.4 diesel as 3.0 T.T. 2JZA80-GTE. Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 8, 2014 Author Share Posted May 8, 2014 £130 for a supposedly newish Garrett turbo sounds off putting. Thats why i wanted people on heres advice Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 8, 2014 Author Share Posted May 8, 2014 Toyota used the same single turbo on 2LT 2.4 diesel as 3.0 T.T. 2JZA80-GTE. So that diesel turbo being weak must be rubbish david? As the twin turbos have held up very well Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 8, 2014 Share Posted May 8, 2014 Thats why i wanted people on heres advice It's reading to me like you wanted people on here to say "yes it's perfect, gosh what a bargain" and they are doing the oppposite. Apart from "it's the wrong size, for the wrong fuel, it's not new, it's old tech, you'll spend thousands trying to make it work even badly and it'll probably explode and trash your engine, if not it'll just be a dog to drive", what more do you need here to unconvince you? Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 8, 2014 Author Share Posted May 8, 2014 It's reading to me like you wanted people on here to say "yes it's perfect, gosh what a bargain" and they are doing the oppposite. Apart from "it's the wrong size, for the wrong fuel, it's not new, it's old tech, you'll spend thousands trying to make it work even badly and it'll probably explode and trash your engine, if not it'll just be a dog to drive", what more do you need here to unconvince you? No i just wanted advice. So i dont really appreciate your comments to be honest. No need for you to even make a comment really. Quote Link to comment Share on other sites More sharing options...
T14PPA Posted May 8, 2014 Author Share Posted May 8, 2014 Thanks for the advice boys. Chris was right. It is a truck turbo. Thats that out the window Quote Link to comment Share on other sites More sharing options...
Noz Posted May 9, 2014 Share Posted May 9, 2014 If you want a cheap turbo at least buy something that's tried and tested with the NA-t crew. Otherwise buy a second hand precision unit. Fly is breaking his NA-t setup. If you want a cheap turbo maybe consider his T61. Otherwise keep an eye out for a second hand unit on here Quote Link to comment Share on other sites More sharing options...
David P Posted May 9, 2014 Share Posted May 9, 2014 Precision products and service are a cross between lottery and pants, I learned the hard way. Quote Link to comment Share on other sites More sharing options...
scott87 Posted May 9, 2014 Share Posted May 9, 2014 I know of a Supra in the uk running a truck garret and its an immense and reliable car! Quote Link to comment Share on other sites More sharing options...
