Mgrene Posted May 4, 2014 Share Posted May 4, 2014 Hello All. This gauge is driving me crazy! A while back it started freezing when I started up the car, got that sorted but now it does this. WTF!? Normally it shows the digitgs in 00.0 and not 0.00 After a few miles drive it goes back to normal mode again. Any of you who know why it does that. Haven't done that since I bought the car a year ago. Quote Link to comment Share on other sites More sharing options...
np89 Posted May 4, 2014 Share Posted May 4, 2014 looks like its reading in lambda? Quote Link to comment Share on other sites More sharing options...
Mgrene Posted May 4, 2014 Author Share Posted May 4, 2014 looks like its reading in lambda? And that means? Quote Link to comment Share on other sites More sharing options...
np89 Posted May 4, 2014 Share Posted May 4, 2014 its another way of reading afr, values between 0 and 1 usually. google it! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 4, 2014 Share Posted May 4, 2014 Its a wide-band so surely it should read 0 to 5 volts if it was reading lambda voltage, are you sure you haven't inadvertently set it to read another fuel type? Quote Link to comment Share on other sites More sharing options...
np89 Posted May 4, 2014 Share Posted May 4, 2014 is there not a switch on the back of them to change it? Maybe its stuck between settings and thats what is making it change between each mode of operation Quote Link to comment Share on other sites More sharing options...
Mgrene Posted May 4, 2014 Author Share Posted May 4, 2014 Its a wide-band so surely it should read 0 to 5 volts if it was reading lambda voltage, are you sure you haven't inadvertently set it to read another fuel type? Haven't touched anything. It just started doing this when I fired up the car today. And then after a while it goes back to normal reading. Maybe a new sensor or gauge is the answer :-( Quote Link to comment Share on other sites More sharing options...
Mgrene Posted May 4, 2014 Author Share Posted May 4, 2014 Yup, it is reading Lambda value instead of showing the normal A/F ratio. Now the question is why and how can I change it back? Quote Link to comment Share on other sites More sharing options...
bignum Posted May 4, 2014 Share Posted May 4, 2014 Sounds like your rotary calibration switch is in the wrong position or inbetween positions, see here, http://www.aemelectronics.com/Images/Products/Installation%20Instructions%2030-4100.pdf Quote Link to comment Share on other sites More sharing options...
Mgrene Posted May 5, 2014 Author Share Posted May 5, 2014 Sounds like your rotary calibration switch is in the wrong position or inbetween positions, see here, http://www.aemelectronics.com/Images/Products/Installation%20Instructions%2030-4100.pdf Yeah I came to the same conclusion yesterday. Just strange that the switch has moved itself. I will try and dismantle the gauge from the dash panels and see if I can move the switch back to its original position. Quote Link to comment Share on other sites More sharing options...
