ID1000cc install
Guest v160
Guest v160
I bought some id1000cc injectors and a old school whifbitz fuel rail i believe it was one of the first whifbitz fuelrails. The injectors won't sit straight, well they do sit straight but once the pump is primed they bend. Is this an issue with me installing them or the fuel rail not being closer to hold the injector in properly?
Looks like the rail is off. I'd contact Paul Whiffin and see if he can help advise on the problem.
If your injector is moving, over time your eventually get a breakdown of material somewhere, the flexing will end up being material failure. Get it sorted before you put the job to rest.
