What's my problem
martincoupe
Your car is fitted with a limiter that recognised you were at 70, it engaged to prevent you speeding.
I was about to say is it an auto, then I seen you were in 5th, so I have nothing to say apart from the voodoo gizmo thingy I mentioned above.
Sounds like the clutch is slipping, generally the symptoms are what you are describing where the revs raise but you don't actually get a speed increase. How old is the clutch? Is the biting point low? Have you smelt clutch burn before?
Don't overtake in 5th
I think at 70, I would have been dropping back in 4th iirc. It is a while since I had my NA 5 speed though but I remember having to thrash it to get anywhere.
Clutch is an easy fix. Problem is, it won't be much quicker when fixed.
H.
I don't mind haters we all have to start off some where and just getting the supra with a manual box made me happy it turns heads every where it goes and as a daily driver it's great on fuel and enjoyment.
If I had the time money etc I would get a twin turbo then out loads of money in to it get lots of power but I just done have that.
