tomsupra1 Posted May 2, 2014 Share Posted May 2, 2014 Hi, When I accelerate or corner fast/hard then the red warning triangle's light up on the dash, as if I have put the handbrake up. Is there a sensor for the handbrake that can be adjusted? Also, on some occasions the interior light comes on as well, meaning the door might be trying to open? Any help appreciated. Regards, Tom. Quote Link to comment Share on other sites More sharing options...
Scott Posted May 2, 2014 Share Posted May 2, 2014 You need to top up your brake fluid Quote Link to comment Share on other sites More sharing options...
Josh42 Posted May 2, 2014 Share Posted May 2, 2014 Check your brake fluid level. Sounds to me that is your problem with the warning lights. No idea on the interior light though Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted May 2, 2014 Share Posted May 2, 2014 As above Quote Link to comment Share on other sites More sharing options...
clay Posted May 2, 2014 Share Posted May 2, 2014 What they said. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted May 2, 2014 Share Posted May 2, 2014 You need to top up your brake fluid Quote Link to comment Share on other sites More sharing options...
Thorin Posted May 2, 2014 Share Posted May 2, 2014 I believe you need to top up your brake fluid. Quote Link to comment Share on other sites More sharing options...
Al Massey Posted May 2, 2014 Share Posted May 2, 2014 Just a guess but you have gremlins in your car Or too up your brake fluid Quote Link to comment Share on other sites More sharing options...
Stonkin Posted May 2, 2014 Share Posted May 2, 2014 Just a thought and as it hasnt been mentioned.... Your brake fluid most likely needs a top up Quote Link to comment Share on other sites More sharing options...
tomsupra1 Posted May 2, 2014 Author Share Posted May 2, 2014 Brilliant Cheers lads, will try that over the weekend. Quote Link to comment Share on other sites More sharing options...
Abz Posted May 2, 2014 Share Posted May 2, 2014 Just in case no one has mentioned it yet... you need to top up your brake fluid Quote Link to comment Share on other sites More sharing options...
np89 Posted May 2, 2014 Share Posted May 2, 2014 Nothing to do with your brake fluid on this occassion. Happened to me last year, adjust the door close indicator on the inside of the door so it definitely pushed the door close switch all the way in when the door closes. You'll find it has probably moved a bit Quote Link to comment Share on other sites More sharing options...
Dazzi Posted May 2, 2014 Share Posted May 2, 2014 Jiggle pin in the thermostat Quote Link to comment Share on other sites More sharing options...
Havard Posted May 3, 2014 Share Posted May 3, 2014 You need to top up your brake fluid This (not sure if it has been mentioned.) The door contact is another good theory though, happened to my old NA iirc. Quote Link to comment Share on other sites More sharing options...
Scott Posted May 3, 2014 Share Posted May 3, 2014 I had an issue with the door switch a few years back too, would sometimes take a few goes of closing the door to get the switch to notice. I'm fairly certain that the 2 issues are unrelated though, as I don't remember the exclamation light coming on for it. IMO clutch fluid definitely needs topped up. That'll do away with the light coming on during braking and accelerating. Giving the switch a wee adjustment should do away with the 2nd issue. Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted May 3, 2014 Share Posted May 3, 2014 When i went above 100 leptons my car did the same on cornering too, it sounds like the door sensor catch as some have mentioned. I sourced one from Keron and the problem seems to have gone. Quote Link to comment Share on other sites More sharing options...
martincoupe Posted May 3, 2014 Share Posted May 3, 2014 I'm pretty new but I'm sure there is something about brake fluid Quote Link to comment Share on other sites More sharing options...
Suprash Posted May 7, 2014 Share Posted May 7, 2014 I was always aware of the brake fluid level, but over the last few days Emma has been getting this indicator in hers, I immediately said "I know why" and went straight to her brake fluid, except the fluid level was fine, so glad there seems to be another common problem, the door switch, thanks Quote Link to comment Share on other sites More sharing options...
