Supra power steering fluid
jazz1
Or Shall I just get the dexron iii Motul stuff as that's what people seem to be using? Also how many litres?
http://www.opieoils.co.uk/showproduct.aspx?ProductID=889&SEName=motul-dexron-iii-fluid-for-automatic-gearboxes-power-steering-systems
Your memory is terrible. The link I posted in the other thread tells you how much is required.
http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine
Power Steering Fluid
Stock Dexron III ATF
I recommend you stick with Dexron III oil but all makes should be suitable
Capacity
Interval = ???
To fully Flush it see here
Capacity
Interval = ???
Auto data says Dextron 2?
That's fine what I'm asking the above Fuchs stuff ok? Or should I go for the motul dexron iii? Which one is better?
Does the Fuchs say what Dextron it is maybe try contacting Alex he is the oil guru on here
I already bought the stuff they recommended this and that's what I bought 4 litres,
http://www.opieoils.co.uk/p-60163-fuchs-titan-atf-4400-automatic-transmission-fluid-for-japanese-cars.aspx
I just want make sure it's correct as it says automatic transmission fluid, website states compatable for dexron III, sorry sound like a noob just thought I'd ask guys on here if it was ok to use.
