Help: Identifying a plastic valve piece - supra mk4 1995 (auto)
Guest Car Driver
Guest Car Driver
Hello fellow supra lovers, I come with another question LOOOOL. I was dealing with my misfiring issue and pulling hoses and such out of the throttle body, where i met my doom with a certain thin hose that leads from the upper throttle body to this plastic purple pipe, I pulled on it really hard and the plastic piece sadly broke off. I have pictures below please help me identify the piece so that i can quickly replace it and be on my way supra-ing down the streets of Sydney.
;_;
P.S - Where i can buy this piece would be helpful, Thanks again fellow members, I love you like i love my mother
This is the piece that was broken off as you can see
Where it exactly came from as pointed by my mate - Its just behind the throttle body if that helps
Edited by Car Driver (see edit history)
It's for the cam cover breather pipe to attach to. It has a one way valve if I recall and it pushes into a rubber seal which pushes into the cam cover. The part should be available from Toyota, I know at least the seal is as I purchased a new one for mine.
Guest Car Driver
Ah lovely, could i get the name or the part number? And yes you are exactly correct of the details :)
Guest Car Driver
Hey guys just wondering, would this gte valve piece work for my n/a http://wtfauto.com.au/component/hikashop/product/75-1jz-gte-2jz-gte-positive-crankcase-ventilation-pcv-valve/related_product-77?Itemid=351
And then try fit a 90 degree hose instead to suit the engine? Because its like 70 dollars and a small child as payment for the piece At toyota T.T
