ccssupra Posted April 30, 2014 Share Posted April 30, 2014 Hi Guys, The heater blows cold when its on the coldest settings, turn it two clicks into warmer and the fans blow 100% hot - so basically no inbetween. Swapped heater controls, what can cuase this? Quote Link to comment Share on other sites More sharing options...
ccssupra Posted May 1, 2014 Author Share Posted May 1, 2014 Anyone? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted May 1, 2014 Share Posted May 1, 2014 I'm no expert but could it be the control arm on the actual heater box moved? It's kind of like a threaded rod with a clip that clamps the rod in the desired position to control the flap that let's the cold/hot air in? Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 1, 2014 Share Posted May 1, 2014 I'm no expert but could it be the control arm on the actual heater box moved? It's kind of like a threaded rod with a clip that clamps the rod in the desired position to control the flap that let's the cold/hot air in? Worth a look but usually if that comes off it doesn't change at all. Quote Link to comment Share on other sites More sharing options...
ccssupra Posted May 1, 2014 Author Share Posted May 1, 2014 Well I can actually hear the motor making the full swing as it were to full heat when I move the dual slightly. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted May 1, 2014 Share Posted May 1, 2014 is there a resistor pack maybe?? Quote Link to comment Share on other sites More sharing options...
