jazz1 Posted April 30, 2014 Share Posted April 30, 2014 Guys I'm at work awkward search I need order these from opie oils, Anyone recommend brands etc please and how much I need please? Link to comment Share on other sites More sharing options...
Josh Posted April 30, 2014 Share Posted April 30, 2014 http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine Use that link, but this is the info in case you can't for some reason. Brake Fluid Stock = Dot 4 I recommend DOT 5.1 Capacity ~1.5L's (Have 2L's ready) DOT 5.1 = Motul RBF600, Castrol SRF Interval = Every 12months (also after any track day!) Power Steering Fluid Stock Dexron III ATF I recommend you stick with Dexron III oil but all makes should be suitable Capacity Interval = ??? To fully Flush it see here Coolant Stock = Toyota 4Life Red Capacity ~9L I recommend you stick with Toyota Coolant. Interval = 30,000miles This should help you with a coolant change. NB: 4Life changes colour as it get older, when it starts to turn a more browny red compared to it's vibrant red when new then it needs to be changed. Also 4Life comes premixed and needs no other liquids mixed with it. Halfords also do their own coolant which I used. It was slightly cheaper than Toyota's and about 10 miles nearer Link to comment Share on other sites More sharing options...
