msupra1 Posted April 28, 2014 Share Posted April 28, 2014 (edited) This is how my drivers side looks: This is how my passenger side looks: As you can see by the photos, the trim is not sitting flush against the window as it should. At the front it is, it's just the back part which leads towards the middle of the door. I was taking the door cards off today along with sound deadening cover thing as I'm getting ready for some new mirrors... and noticed it smelled really bad and lots of moisture and some water drops in there. I'm thinking that's because of the exposed hole at the top. I believe it was like this when I purchased the car nearly 2 years ago, someone must of tried breaking into it or something. Anyways is there any suggestions how I can about to repair this? Would like this done before the door is put back together. Can the trim be somehow adjusted, or would I need to purchase new trim? or is it not the trim and possibly another issue? regards Edited April 28, 2014 by msupra1 (see edit history) Quote Link to comment Share on other sites More sharing options...
Kaan W Posted April 28, 2014 Share Posted April 28, 2014 Pictures won't load on my phone but it sounds as if it's not clipped in correctly, I had this on one side when putting my trim back on as I tried to fit it with the window still up. You will need the window down as they clip in at an angle I believe 5 clips that have to slot in the holes in the door. Quote Link to comment Share on other sites More sharing options...
msupra1 Posted April 28, 2014 Author Share Posted April 28, 2014 As a side question, on the lower part of the windows, which are inside the door at all times (even when fully detracted)... they are very dirty and even have greed on them. Are they easy to remove? would like to clear that up. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted April 28, 2014 Share Posted April 28, 2014 Yes two bolts that are easily accessible with the door card removed Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 28, 2014 Share Posted April 28, 2014 isn't there a screw on the end also Quote Link to comment Share on other sites More sharing options...
msupra1 Posted April 29, 2014 Author Share Posted April 29, 2014 can anyone else confirm about the clips? do I just simply try and push it towards the window, and should clip into something? Quote Link to comment Share on other sites More sharing options...
msupra1 Posted May 4, 2014 Author Share Posted May 4, 2014 ? Quote Link to comment Share on other sites More sharing options...
listy Posted May 4, 2014 Share Posted May 4, 2014 Take the door card off and have a look. Takes ten minutes to remove. Quote Link to comment Share on other sites More sharing options...
msupra1 Posted May 5, 2014 Author Share Posted May 5, 2014 As you can see by the photos, the door cards have been removed. Quote Link to comment Share on other sites More sharing options...
nevins Posted May 5, 2014 Share Posted May 5, 2014 To take them off, it's two screws one either end once the door card is removed. Once they are out it's a simple case of rolling motion towards the car so inwards and they pop off. The clips so to say slot down vertically through a number off holes. Mine are currently going back on due to a respray. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted May 5, 2014 Share Posted May 5, 2014 Take the door card off and have a look. Takes ten minutes to remove. Even I could do it faster than that Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted May 5, 2014 Share Posted May 5, 2014 There are three bolts on each window. I dismantled two doors on Saturday. You can remove them with the window up. There are slots in the door panel to access them. In order to slide it out you will also have to unbolt and remove two stopper. These two control the top height of the window when up. It's very easy. Quote Link to comment Share on other sites More sharing options...
nevins Posted May 5, 2014 Share Posted May 5, 2014 No need for the window to come out to take the strip of mind. Quote Link to comment Share on other sites More sharing options...
