Tow hook body kits
jazz1
Ok my supra is going in for a full respray next month and I plan on somehow fitting some tow hooks, I have trial rear and do luck front. I would prefer to just fit one on the rear rather the front. Currently the only way I could fit a tow hook to the car is remove the front bumper and fit the hook which is always in my car. But I rather have one fitted than do all that if I had to use one etc. So to you body kit kit guys where is your tow hook as judging but most people I can not see one:cool:?
Easy enough, just do some careful measuring and use a screw in type, just need to make a threaded piece
for it to screw into which you would still attach to the leg , cut a round hole in the bumper and get
a clip in plug to fill the hole
I don't mate. It was something I kept thinking about too, but I'm the same, I don't want one showing.
Well always keep one in your car then with tools to take of your bumper ;) incase they cheap on eBay.
- - - Updated - - -
Easy enough to do some careful measuring and use a screw in type, just need to make a threaded piece
Perfect :) where can I buy these plastic clip on plugs.
Where would that fit on a supra?
Or would you need to drill and tap
If it were me i would fabricate a bracket welded or bolted to the outer face of the chassis leg
with a tube welded to that with the same thread as the towing eye.
Thanks DNK you. Even very helpfull, perfect :).
It might be possible to fit it elsewhere depending on the space you have behind the
bumper.
I was going to fit one on my car and have it coming through the center hole for the air
intake and just cut a small hole in the mesh, there was plenty of room to do this on my
car even with the HKS R spec intercooler, in my favour the hole in the TRD bumper
is quite big.
You could even fit it into the crash bar between the chassis legs then hidden behind
the reg plate.
  • 4 weeks later...
