Guest v8lee Posted April 24, 2014 Share Posted April 24, 2014 Hi can anyone help I've got an R reg mk4 Toyota Supra I lost my ignition key so to move it I un screwed the plastics removed the ignition barrel fitted a second hand 1 but now it won't start was my key chipped to the ecu thanks Link to comment Share on other sites More sharing options...
listy Posted April 24, 2014 Share Posted April 24, 2014 I doubt any one will help with this one. Seems a bit dodgy the first post being a question about how to start a supra with no key. Link to comment Share on other sites More sharing options...
Gaz6002 Posted April 24, 2014 Share Posted April 24, 2014 I doubt any one will help with this one. Seems a bit dodgy the first post being a question about how to start a supra with no key. Something very strange about this and I'd suggest members don't answer this question - especially on a public forum. Link to comment Share on other sites More sharing options...
jamesmark Posted April 24, 2014 Share Posted April 24, 2014 Hi can anyone help I've got an R reg mk4 Toyota Supra I lost my ignition key so to move it I un screwed the plastics removed the ignition barrel fitted a second hand 1 but now it won't start was my key chipped to the ecu thanks I doubt any one will help with this one. Seems a bit dodgy the first post being a question about how to start a supra with no key. Something very strange about this and I'd suggest members don't answer this question - especially on a public forum. Agreed. And to finish thread off. Tow car along with proof of ownership etc & ID to an alarm specialist to resolve. EDIT: Also check with your insurer as you may have lost key cover. Link to comment Share on other sites More sharing options...
listy Posted April 24, 2014 Share Posted April 24, 2014 Where in Wales are you? Link to comment Share on other sites More sharing options...
TT Paul Posted April 25, 2014 Share Posted April 25, 2014 the KEY point here is where to START Link to comment Share on other sites More sharing options...
Rummy Posted April 25, 2014 Share Posted April 25, 2014 I doubt any one will help with this one. Seems a bit dodgy the first post being a question about how to start a supra with no key. I'm no superhero, but my senses were tingling on this one too.... ...although it may have something to do with the minty shower gel I've just used Link to comment Share on other sites More sharing options...
TubbyTwo Posted April 25, 2014 Share Posted April 25, 2014 I have just nicked a car and dont have the key. Can someone help me bypass the ignition so I can drive it to my lockup? Thanks Link to comment Share on other sites More sharing options...
Guest v8lee Posted April 25, 2014 Share Posted April 25, 2014 I understand the people thinking it was strange no key and none starter. I've dropped car off to a local electrician, just thought there might of been an issue with key and ecu. I'm not in Wales i'm in Birmingham Link to comment Share on other sites More sharing options...
listy Posted April 25, 2014 Share Posted April 25, 2014 I understand the people thinking it was strange no key and none starter. I've dropped car off to a local electrician, just thought there might of been an issue with key and ecu. I'm not in Wales i'm in Birmingham Yeah my ip locator was playing up. However, on trying another (another mod confirmed too) found your IP address to be located in London Link to comment Share on other sites More sharing options...
Guest v8lee Posted April 25, 2014 Share Posted April 25, 2014 Well i'm in the middle sort of Link to comment Share on other sites More sharing options...
Tayfun.tugra Posted April 25, 2014 Share Posted April 25, 2014 hello I thought i'd find my supra here... can i have it back please? Link to comment Share on other sites More sharing options...
Guest v8lee Posted May 9, 2014 Share Posted May 9, 2014 Apparently I blew relay on fuel pump. Next problem I've brought a lsd unit but it's for the big diff. If I find a big diff will it fit straight under my back end or are the shafts different lengths Link to comment Share on other sites More sharing options...
Scooter Posted May 9, 2014 Share Posted May 9, 2014 Shafts (or at least one) are different. There is a large LSD diff with casing and driveshafts here http://www.mkivsupra.net/vbb/showthread.php?307154-Uk-big-diff but you may be better off with selling yours and getting a small LSD in a casing at around £250 all in? Link to comment Share on other sites More sharing options...
David P Posted May 9, 2014 Share Posted May 9, 2014 N/S drive-shaft is shorter and so is the prop-shaft. The LSD unit could be fitted into your present casing. Link to comment Share on other sites More sharing options...
Guest v8lee Posted May 9, 2014 Share Posted May 9, 2014 I'll put on Ebay and get a small casing diff thanks. the lsd thing I've brought has 2 more bolt holes were the crown wheel bolts Link to comment Share on other sites More sharing options...
