Seriously need help removing suspension
Guest Knightrider1980
its ok guys, i loostened the bolt for the A -arm, just need to remove the washer, to slide the bolt out then i can take the damn stock damper out.
This is weird because I've never had to do any of what you guys are saying.
How I do it is to leave the top three nuts on but loose, undo the bottom shock bolt and the stand on the hub to allow to lift the stock over the bottom arm.
Then hold the stock with one hand the undo to three nuts with the other, the stock will then drop down.
Stand on the hub again and lift the stock out.
I weigh 80KG mate and that hub didnt move on the fronts at all!
On another note I think my coilovers are jammed, its not budging at all....my car looks like a 4x4 at the moment :(
You need to get some pies down you and try again, or try having a shower with your clothes on :D
Hiya guys, just to say that finally removed the son of a bitch :D, just installed the tein damper, 1 down 3 to go, but will do them 1 day each, so 3 days the car will have full racing suspension, supra_ufo thanks for the help, to all of you who commented thank you for the help also, and keron thanks for telling me what spanner to use lol
