Na-T oil drain questions
SupraP-Z
Morning all,
A few q's about the oil drain line. Is there a way of just dropping the sump instead of pulling the whole engine?
Secondly what size hole needs to be drilled into the sump for the oil drain line?
Last one about the oil feed - I have a sandwich plate, i wont be needing the lexus union bolt for the oil feed will I?
Thanks
Edited by SupraP-Z (see edit history)
