Chris_K's Custom GT35R build
Chris_k
Latest pic:
Current Spec:
Engine Spec & under bonnet mods
V160 Gearbox
ARP head bolts
Powder coated Cam covers
Powder coated bottom runners&plenum
SRD Rad
SRD Rad plate
SRD intercooler plate
New waterpump
FCD
Turbocharger & Induction
Garret GT3582R
Oil&water feed and return lines from SRD
Custom made manifold by Pulley
60mm watsegate with screamer pipe
K&N Filter
FMIC
HKS SSQV BOV
16ROW oil cooler
Fuel, Tuning & ECU
Greddy E-Manage Ultimate
Walbro 255 fuel pump
Blitz dual sbc spec r boost control
NGK Irridium 8s
Uk Spec 550cc iinjectors
SRD fuel pulsation remover
Exhaust
Blitz nur spec R
3" custom downpipe with flexi
Suspension, Wheels, Tyres & Brakes
18x10j all round Rota Grid Drifts with Falken tyres
UK spec discs
UK spec pads front/rear
UK spec 4 pot front and 2 pot rear calipers
Goodridge braided hoses from Whifbitz
Tein springs
Interior & ICE
Black leather seats
52mm boost guage
Twin A pillar pod
Infinity Speakers
Alpine Headunit
AEM wideband AFR
Greedy turbo timer
Ive owned my supra now for 4 years and thought that it would be a good to get up a progress thread!
I'll give you a bit of background first, bought my Supra from a member called Mcgoo on here.
When i bought it it was a RZ twin turbo 6 speed BPU. I absolutly loved the car and used it as my daily for nearly 2 years. When fuel costs were becoming an issue for me i got myself another run around and started to take it off the road over winter. Car was running 430bhp and this was more than enough and loved the power.
4 weeks before Japfest 2013 i lost all boost, and was so upset when i couldnt find what was wrong with it. After looking through so many threads to find what it could be and checking boost pipes and solinoids it came down to the fact that my 1st turbo had failed. Pritty dramatically.
Most of the blades on the hot side had pritty much been destroyed, was planning on getting myself another set of twins and swopping. After some convincing from Mark (Pulley) we decided that going single was the way forward.
After many cuts to my hands and impossible bolts to remove, the old knackered turbos were removed:
Got a couple pics with the guys that helping me. Mark and Ant's supras, also Laurence helped.
When removing few parts it came to our attention that a few extra bits of work were needed. Subframe had almost rotted through, so mark got on the phone to Keron and a new subframe turned up 2 days later, got it painted up and ready to fit.
Edited by Chris_k (see edit history)
Origionally wasnt planning on removing the head but seeing as its 20 years old i thought it would be a good time to give it another new hg and extra cleaning.
Also had new Stem oil seals fitted by Mark, we cleaned the head up again and that was ready to go back on.
Block was cleaned up ready for new head.
Had to start ordering parts now and the bit i was most excited about was the turbo. Managed to source it from Kaan a GT3582R
Thought id have a selfie with my turbo :D
Head went back on, cams in, pulleys on.
Meanwhile Mark (Pulley) was busy making me a custom hi-flow manifold to house a 60mm wastegate, custom made downpipe and fabricated a few more peices to make everything work.
Absolutly stunning work with perfect custom fitment
There was some late nights!
Perfect fit for wastegate and screamer pipe:
Downpipe with flexi welded in to protect it
Finished product, coated and wrapped:
Some new goodies ordered from SRD with a couple other pieces purchased off the fourm
Parts list:
Large K&N filter,
NGK irridium 8s
SRD Rad
Rad hoses
550 injectors + resister pack
HKS SSQV BOV
Cooler for PAS
Oil Cooler
Whifbitz turbo blanket
SRD oil feed and return lines
New thermostat
Rad plate
Intercooler plate
Fanbelt
Emanage Ultimate with field harness
4" ally pipe for intake
Oil catch tank
Ash oil breathers
Got cambelt back on, all timed up.
Mark also welded on an -AN fitting for water return and blanked off the old fittings.
Test fitting manifold turbo, blanket, oil&water feed and return lines:
All my radiators/coolers :)
Intercooler mounted with custom plates made by mark, underside support also has PAS and oil cooler mounted.
Manifold bolted and downpipe bolted on.
Turbo Mounted, all feed and return lines connected up
Lots of bits returned from powdercoaters, all done in black as wanted a stealthy bay.
Inlet manifold and plenum mounted up.
Silicone joiners cut to size and mounted along with K&N. Throttle body attached, will be removed at a later date to be painted black
Nice delivery from Opie Oils :)
Big start up should be next week!
Thanks guys, yeah I can't wait to get it spooling kaan!
The engine is all back together now I just need to finish off the thread. Haven't started it up yet. Will be next week the big turn on!
As said the GT35R makes for a great fast, responsive setup, the 550cc injectors are going to limit how much boost you can run though.
Yeah I appriciate the 550s will limit it but am planning a low boost set up for now. With future plan of getting some 750s maybe.
The jump from 430 to 500-550 will be enough to keep a smile on my face for a year at least.
  • 1 month later...
Havent updated in a while so thought id give you an up to date picture of whats happening. Car started first time and ran really well, very happy with it.
Getting ready to put final bits onto car
Fitted and restored headlights:
Bonnet on:
Getting ready for MOT late at night had no sidelights, had to rewire all of it to get them running. Finally got them working
First time it left the garage in nearly a year.
Treated supra to some new wheels too, ones I have always wanted:
Got myself a new boot too as mine has the usual rust spots round the base edge, anyone for a supra pickup?
