Want to BPU - Bosch 044
ccssupra
Hi Guys, I have a JSpec 94' TT Auto and im wanting to do BPU the best and safest way possible.
Already have a brand new SMIC on order from Whifbitz, and before I actually start putting performance parts on I want to replace the fuel pump.
Is it a simple swap out job to fit the Bosch 044?
The Bosch 044 pump is a lot larger than the stock fuel pump so is not a straight swap into the stock hanger (see install pic HERE.)
At BPU/small single levels of performance most use the (GSS342) Walbro 255ltr/h pump which is a straight swap for the stock j-spec fuel pump, it's a straight forward job to swap over once you get to the hanger.
