Argyle dan Posted April 19, 2014 Share Posted April 19, 2014 Just want to say hi, to everyone. I will be on here a lot in the coming months,asking for information, best way to tune, ect. I have decided to put a 2jz gte into my Lexus is200. Good idea,bad idea I don't know yet,probably won't be enjoying it when I have to do the wiring, I've managed to get myself an engine, just looking for a gearbox now and I can start this project.Just gathering parts at the moment so everything goes to plan.( I hope). Cheers Dan Quote Link to comment Share on other sites More sharing options...
listy Posted April 19, 2014 Share Posted April 19, 2014 Twin turbo or NA? If NA, why not just get an IS300 (I think) which has the 2JZ-GE engine already. Quote Link to comment Share on other sites More sharing options...
Argyle dan Posted April 19, 2014 Author Share Posted April 19, 2014 Sorry forgot to say, TT jap spec engine . Quote Link to comment Share on other sites More sharing options...
Guest MINTER Posted April 19, 2014 Share Posted April 19, 2014 cant give much advice,although id sayit would be mental if you get it in,few lads over here have RB25s in Is200s and they are pretty insane!cant imagine what a TT 2jz would be like Quote Link to comment Share on other sites More sharing options...
Axl Posted April 19, 2014 Share Posted April 19, 2014 I've got an is200 it's great but it would be a right weapon with a 2jz gte in it but I think your going to have a nightmare with the wiring also upgrade the suspension because of extra weight check out the lexus forum a popular engine swap is the v8 Quote Link to comment Share on other sites More sharing options...
Argyle dan Posted April 20, 2014 Author Share Posted April 20, 2014 Suspension and brakes have all been done, got supra 4 pots on front,hks hyper max plus fully adjustable suspension and braces front and rear.. Wiring is going to be a nightmare, haven't really thought how I'm going to do it, but other people have done it, so it must be possible. Quote Link to comment Share on other sites More sharing options...
Axl Posted April 20, 2014 Share Posted April 20, 2014 Good luck then buddy post some pictures they love pictures on here Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted April 20, 2014 Share Posted April 20, 2014 (edited) Welcome along, guessing you are in the Plymouth area Funnily I was talking about this very conversion with someone recently and how it should be possible We were talking about it because they had seen a conversion project on EBay Edited April 20, 2014 by DodgyRog (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted April 20, 2014 Share Posted April 20, 2014 (edited) I recently fitted a 2JZ-GE in my Mk3 Supra . . . but I spent MONTHS sussing out all the parts I needed to make it fit, and get hold of them all. Plus I spent over 100 hours pouring over the Mk3 and Mk4 circuit diagrams, sussing out what I needed to do to make all the electronics work, all the gauges, Power Steering, ABS, Cruise Control, Aircon, etc etc. I also found loads of INCORRECT information on different websites/forums! I ended up making up adaptors for the engine loom body plugs so it would be plug & play, with just a few connections to hardwire after the swap. All my preparatory work proved worthwhile, as the car was only off the road for 2 days ! (people were telling me it would take months!) So good luck mate . . . I'm in the process of doing a full write-up, but sadly most of my sussing out would be of little help to you . . . Edited April 20, 2014 by Roger NE (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted April 20, 2014 Share Posted April 20, 2014 Many folks on here are confused by such abbreviations as "GTE", "N/A or T.T. mate", is about standard linguistic performance. Quote Link to comment Share on other sites More sharing options...
Argyle dan Posted April 21, 2014 Author Share Posted April 21, 2014 Yeah I'm in plymouth, getting the engine and box in is the easy bit, I don't mind the fabrication and all that, just trying to work out electrics, I'm currently running a is200 with tte supercharger kit with 160mm pulley with a greddy emanage ultimate. It's running 260bhp atm but time has come for a change. For what I would spend on upgrading the internals on a 1G-FE (and for little gain) I might as well go for something different. With a bit of luck I can still use the emanage , still haven't worked out the wiring, weather to use the supra harness or modify the is200 harness. I know I have to keep the is200 Ecu for some things, so hours of fun to look forward to. Just trying to get everything ready so it goes according to plan and my car is off the road for as little time as possible. Quote Link to comment Share on other sites More sharing options...
