Tommyd16 Posted April 19, 2014 Share Posted April 19, 2014 Has anyone fitted these with BPU setup? Any idea what sort of gains are expected? What sort of stall speed is needed for BPU? Thanks Quote Link to comment Share on other sites More sharing options...
mellonman Posted April 19, 2014 Share Posted April 19, 2014 If you have a bpu in sequential there is hardly any gains at all to be had just a quicker harder gear change, they are more aimed at more higher power cars, kann on here has one on car and he destroyed one of them, I see a video on you tube where a competing company opened up the box and it was practacly the same box with packers fitted in the solenoid springs to make the closing force greater Quote Link to comment Share on other sites More sharing options...
Kaan W Posted April 19, 2014 Share Posted April 19, 2014 That's correct I did have one, still unknown what caused the converter to fail but when it was working it was excellent. Gear changes and characteristics of the box remain unchanged unless you have a built box but you will launch quicker but also loose top end. I had a single setup and my 3800 stall could brake boost to 3000rpm. This made a dramatic difference to acceleration, with bpu on stock twins a 3800 will launch the car in the middle of the power band which will give a great launch. I since have a new converter which I'll be testing with my big singlex hopefully it was down to a dodgy batch of converters. Quote Link to comment Share on other sites More sharing options...
Hassan Posted April 19, 2014 Share Posted April 19, 2014 How much top end do you loose? And you still using a titan converter? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted April 19, 2014 Share Posted April 19, 2014 How much top end do you loose? And you still using a titan converter? Not specifically Titan converters but all converters the higher the stall you get more slip thus top end wouldn't be at its potential. Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted April 19, 2014 Author Share Posted April 19, 2014 What is the supras top end? You would recommend getting the Titan torque convertor then? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted April 19, 2014 Share Posted April 19, 2014 What is the supras top end? You would recommend getting the Titan torque convertor then? Yeah definitely, top end regardless of what stall you go for is more than enough. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 20, 2014 Share Posted April 20, 2014 You need to read up on what a torque converter is and why it's there It is to allow an engine to rev to a point in the RPM band where it makes strong torque to allow excellent acceleration from a standstill. If you put a big turbo on a stock engine that moves the useful part of the torque curve upwards, or fit camshafts with more duration, that do the same, then a higher stall RPM converter will assist off the line acceleration. If you don't NEED one it will make the car do pitiful MPG, raise the transmission fluid temperature severely in traffic driving, make it sound like you are a learner driver to bystanders, and you will probably be fed up with it within a month. Totally unsuited to a car on stock turbos, and totally unnecessary. Quote Link to comment Share on other sites More sharing options...
flyby Posted April 27, 2014 Share Posted April 27, 2014 Can some clarify somthing I've read (some where on the big Internet). There should be a problem if you install the HI-converter on a standard ECU, because it will not go higher than 3000 RPM if it does not moving, is that correct? Or is the HI-stall just at build on and run product ? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 27, 2014 Share Posted April 27, 2014 It sounds entirely feasible, the ecu monitors engine RPM, gearbox input shaft RPM, and tailshaft RPM. Iyt probably checks them against a table and if it sees what it considers strange figures may "do something". Quote Link to comment Share on other sites More sharing options...
mellonman Posted April 27, 2014 Share Posted April 27, 2014 I have heard that a Hi stall speed and cause issues with the lock up, Quote Link to comment Share on other sites More sharing options...
