While I'm sorting out the fuel....
Scott
I wanted to check for leaks etc so I connected my B+ to the FP and turned on the ignition. Pressure went up to just over 5 bar which I understand is way too high.
Would this be considered a good leak test? It was pissing fuel at the regulator before I realised I hadn't tightened it :innocent:
Now that I've checked everything over and made sure everything is tight, it's holding fast at just over 5bar and there isn't a noise to be heard.
Next, I'm guessing 36psi is the standard figure even for a single turbo, until the mapper gets his hands on it anyway. So I guess I can drop the pressure down to just over 2 bar and leave it set there to limp down for mapping?
Thanks
