Syvecs Fuel Pump Trigger
Scott
Does anyone know the circuit for starting the fuel pump with a Syvecs on board? I'm about to email Ryan but I thought I would ask here just in case I could get the answer right away.
I turn the ignition on, the relay on the syvecs loom clicks on but the fuel pump doesn't come on. I've checked the diagnostic port and B+ is getting 12v when the ignition is on, if I bridge the B+ and FP the fuel pump comes on as expected.
I'm just wondering if the circuit is exactly the same as stock? I don't want to start fault finding based on the stock system only to find it triggers differently :)
Cheers
Scott
did you find the answer to this ?
Not yet, Ryan can be quite busy at times so it will take a few days for a reply.
While I was waiting I checked out the EFI relays etc, everything there is working fine so the fuel ECU is definitely getting 12v. I can only assume it's one of the triggers that isn't working now, possibly the wrong pinout or a broken wire or something.
Cheers
