chazuk Posted April 19, 2014 Share Posted April 19, 2014 I am trying to start up my single engine on the stock ecu just to run it up in the garage check everything is good before it goes off for a ecu and map I've done this before in the past and its been okay , I've put the stock injectors in the only two things that is different this time is a aftermarket 3bar map sensor and the tps is wired up using the trac tps for the greedy intake , the car turns over but does not prime the fuel pump any ideas ? I can make the pump run via the diagnostic port , my immobiliser is switching off as I can hear the tick of the relay, Quote Link to comment Share on other sites More sharing options...
David P Posted April 19, 2014 Share Posted April 19, 2014 Not sure re. the Gr Eddy gizmo, but you'd be better off with the stock map sensor to get you there. Quote Link to comment Share on other sites More sharing options...
